Results 1 to 4 of 4
    Veteran Member Four Rings PKmode's Avatar
    Sep 19 2005
    Milwaukee, WI USA
    No pollen filter?
    So I was under the hood and pulled back the rain guard and looked into the intake duct of the cabin air inlet. To my surprise, after the plastic large hole screen on top on the inlet, there was no filter. I could see the blower motor clear as day. That doesn't seem right. I wnet to my local dealer and asked for the filter and they could only come up with a part number for the cabin air filter, which is behind the dash, after the blower motor. They said there is no filter there which seems crazy.
    Can anyone confirm? If you do have a filter there, could you please post a picture or a part number?
    Thanks in advance.
    Do it right, or don't bother.
    Active Member Two Rings Owlbandit's Avatar
    Sep 17 2013
    Lehigh Valley, PA
    Doesn't look like there is a filter under the hood. Only the cabin air filter.
    This may help... http://parts.audiusa.com/a/Audi_2013...N/1353135.html
    Quote Originally Posted by PKmode View Post
    Thanks in advance.
    2013 Phantom Black - Black Optics Grille - Satin Black Rear Diffuser - 20" RS6 Hartmann Winter Wheels - LED Headlights - Driver Assist - Carbon Inlays - Cold Weather Package - 35% Tint - VAG-COM - Passport Max2 Hardwired - K&N Air Filter - Unitronic Stage 1+ - Eurocode Trans/Diff Mounts - Dipstick Added
    Sep 19 2005
    Milwaukee, WI USA
    Thanks, That is the diagram we had pulled up but it doesn't show the intake side under the hood really. I guess maybe there really isn't one but it seems odd as stuff could get right into the blower.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    In certain countries there is a pre-filter as you described. I think the China version has it. I believe it can be retrofit but requires other trim parts.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
