    Aug 23 2010
    France
    Exclamation "ESP FAULT! - Consult drivers manual"
    Hi,
    Since few days now, I get the waring message ""ESP FAULT! - Consult drivers manual" on my Audi A4 B8 (2009).
    Once I stop the engine and restart, the default disappear...till I turn the steering wheel and the message appear again.
    So I assume that I get an issue with my steering angle sensor.
    I plug my VAG-com, clear all DTC and move the steering wheel to get the error message and scan again.
    Once clearing DTV, I get this scan:
    Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 022 NN HW: 03L 906 019 AL
    Component: R4 2,0L EDC H21 5483
    Revision: 25H21---
    Coding: 0A194012232403080000
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_ECM20TDI03L906022NN A02006
    ROD: EV_ECM20TDI03L906022NN_AU48.rod
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 BT HW: 8K0 907 379 BT
    Component: ESP8 front H04 0010
    Revision: -------- Serial number: --------------
    Coding: 164D0C
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
    Component: BCM2 1.1 H02 0324
    Revision: 00002001
    Coding: 030100
    Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H37 0060
    Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AK HW: 8T1 820 043 AK
    Component: KLIMA 3 ZONEN H08 0171
    Revision: C1000000 Serial number: 01250820090833
    Coding: 3C300000
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H25 0380
    Revision: 10025001 Serial number: 00000000334591
    Coding: 260050914074AF201601000300001D0D439C03280401014100 0000
    Part No SW: 8K1 955 119 A HW: 8T1 955 119
    Component: WWS 250809 H06 0070
    Coding: 00FD11
    Part No SW: 8K0 955 559 HW: 8K0 955 559
    Component: RLS H04 0003
    Coding: 025028
    Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
    Component: PARKHILFE 8K H06 0070
    Revision: 11001001 Serial number: 50941027909582
    Coding: 300107
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
    Component: AirbagVW-AU10 H39 0560
    Serial number: 003EFD058ESE
    Coding: 30343435363030303030554A304C384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H16 0014
    Revision: -------- Serial number: 90315IHP0000K
    Coding: 000016
    Component: E221 - MFL H02 0003
    1 Fault Found:
    00888 - Wiper Switch for Intermittent Operation (E22)
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 99692 km
    Time Indication: 0
    Date: 2016.04.07
    Time: 17:46:04
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 900 K HW: 8K0 920 900 K
    Component: KOMBIINSTR. H19 0253
    Revision: 00300000 Serial number: BWZ318489
    Coding: 0F0D080003000008030000
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L
    Component: GW-BEM 5CAN-M H10 0105
    Revision: FB900055 Serial number: 5500F0980701B7
    Coding: 00CF07
    Address 20: High Beam Assist. (J844) Labels: None
    Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
    Component: FLA H04 0004
    Revision: AA001002
    Coding: 02019164747464545425363E
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 J HW: 8K0 959 793 E
    Component: TSG FA H11 0306
    Revision: Serial number: 0000101746907
    Coding: 011C02204000410001
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0120480431
    Coding: 01000620003904400320010400000000
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 J HW: 8K0 959 792 E
    Component: TSG BF H11 0306
    Revision: Serial number: 0000101701501
    Coding: 011C02204400410001
    Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 00000000434948
    Shop #: WSC 00000 000 00000
    Address 55: Xenon Range Labels: 8K0-907-357.clb
    Part No: 8K5 907 357 A
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000004
    Shop #: WSC 06324 000 00000
    Address 56: Radio (R) Labels: None
    Part No SW: 4F0 035 053 K HW: 4F0 035 053
    Component: Radio U Basic H45 0074
    Revision: AB001007 Serial number: 341H%097628739
    Coding: 010003020000000001
    Address 5F: Information Electr. (J794) Labels: None
    Part No SW: 8R1 035 664 B HW: 8R1 035 664 B
    Component: H-BN-NA H43 0793
    Revision: -------- Serial number: 203IU0C7506523
    Coding: 110100000206E3EF4580FF5E00000403140000000000000000
    Shop #: WSC 02391 823 56573
    2 Faults Found:
    03175 - Invalid Data Set
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 99692 km
    Time Indication: 0
    Date: 2016.04.07
    Time: 17:47:23
    Freeze Frame:
    Voltage: 11.80 V
    03389 - Data Set Implausible
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 99692 km
    Time Indication: 0
    Date: 2016.04.07
    Time: 17:47:23
    Freeze Frame:
    Voltage: 11.80 V
    Bin. Bits: 010
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
    Component: TSG HL H10 0306
    Revision: Serial number: 0000101708259
    Coding: 010402204000210001
    Address 6C: Back-up Cam. Labels: 4L0-910-441.lbl
    Part No SW: 8T0 907 441 B HW: 4L0 907 441 A
    Component: J772__Rearview 0070
    Revision: --H12--- Serial number: 525PA8-J8291OU
    Coding: 1020006
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
    Component: TSG HR H10 0306
    Revision: Serial number: 0000101707860
    End ---------------------------------------------------------------------
    When I create the "ESP Fault message", I get this scan:
    Revision: 25H21---
    2 Faults Found:
    4698 - Function Restriction due to Received Malfunction Value
    U1113 00 [036] - Open or Short to Plus
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 99692 km
    Date: 2016.04.07
    Time: 17:49:28
    4699 - Function Restriction due to Received Malfunction Value
    U1113 00 [036] - Open Circuit
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 99692 km
    Date: 2016.04.07
    Time: 17:49:28
    Coding: 164D0C
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 99692 km
    Time Indication: 0
    Date: 2016.04.07
    Time: 17:49:28
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x40A2
    Hex Value: 0x001C
    Hex Value: 0x23A5
    Hex Value: 0x00FF
    Revision: 00002001
    Coding: 030100
    Coding: 3C300000
    Coding: 00FD11
    Coding: 025028
    Coding: 300107
    1 Fault Found:
    01315 - Transmission Control Module
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 99692 km
    Time Indication: 0
    Date: 2016.04.07
    Time: 17:45:46
    Freeze Frame:
    Temperature: 25.0°C
    Coding: 000016
    2 Faults Found:
    014 - Defective
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 99692 km
    Time Indication: 0
    Date: 2016.04.07
    Time: 17:46:04
    00778 - Shareware Version. To Decode all DTCs
    008 - Please Register/Activate - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 12
    Mileage: 99692 km
    Time Indication: 0
    Date: 2016.04.07
    Time: 17:49:29
    Freeze Frame:
    (no units): 44.0
    Text: 2CFFFFFF8EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00FFFFFF C0FFFFFFFF
    Raw, Form. N/A: 255 255 000
    Text: 22FFFFFFA1FFFFFFC300190AFFFFFF88FFFFFFC200
    Bin. Bits: 11000011 00000000
    Mass Flow: 193.48 g/s
    Raw, Index/Key Err.: 194 000 118
    Coding: 00CF07
    Revision: AA001002
    Coding: 0000004
    5 Faults Found:
    03276 - Please Check Software Version Management
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 99692 km
    Time Indication: 0
    Date: 2016.04.07
    Time: 17:47:24
    Freeze Frame:
    Text: DUA130,Fro
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 99692 km
    Time Indication: 0
    Date: 2016.04.07
    Time: 17:47:23
    Freeze Frame:
    Text: nt,M,0,0,6
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 99692 km
    Time Indication: 0
    Date: 2016.04.07
    Time: 17:47:23
    Freeze Frame:
    Text:
    Text:
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 228
    Mileage: 99692 km
    Time Indication: 0
    Date: 2016.04.07
    Time: 17:47:30
    Freeze Frame:
    Bin. Bits: 00000000 00000000
    Bin. Bits: 00000000 00000001
    Bin. Bits: 00000000 00000100
    03278 - Functionality Limited due to Missing Messages
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 99692 km
    Time Indication: 0
    Date: 2016.04.07
    Time: 17:47:32
    Freeze Frame:
    Coding: 1020006
    So seems that my steering angle sensor is the one responsible of my issue, Isn't it?
    My "ESP fault" generate:
    - Faults on Module 01 'Engine'
    - Fault on Module 03 'ABS'
    - Fault on Module 10 'Park/steer assist'
    - 1 add. fault on Module 16 'steering wheel'
    - 3 add. faults on Module 5F 'Information Electr.'
    Right? ;)
    Thanks in advance for feedbacks,
    David
    Feb 10 2016
    France
    Hi dave, i see there is recurrent default in your system. May be this link can help you to understand what is going on. If you don't understand French, just translate it, it's technically very strong. See u
    Aug 23 2010
    France
    Unhappy
    Hi,
    I came back on my 'ESP fault' issue...
    I bought a spare (1050Km) steering sensor angle from ebay..
    > I switch them (existing = 8K0 953 568 G and 'new' one 8K0 953 568 G also)
    > Using VCDS, I calibrate the new sensor ('zeroing' it :)
    > I clear DTC
    > try to turn the steering wheel from right to left few time, make a short drive....no more ESP fault!
    I thought "finally I'm done with this issue"...but after new scan, I get a 'faulty Cruise control switch (E45)'.
    The chance to get a faulty switch while changing my engle sensor is really small so I check all connections, cables, etc...but error still there.
    Then I decide to install back my 'old' sensor angle, make new scan...and...
    ESP fault appear again (of course! :)
    Cruise control fully OK
    So, 2 possibilities:
    Is there any re-coding to realize after sensor angle replacement?
    OR
    My 'new' sensor angle is simply faulty??
    Thanks for your feedbacks,
    Jun 26 2009
    Bremerton WA
    On module 16 does the coding match for both components?
    VMR 710's, APR software, Eurocode HFC
    Aug 23 2010
    France
    Quote Originally Posted by van462 View Post
    Which coding?!!
    The only thing to do is calibration of the SAS...no coding required as ECU (module 16) already coded with CCS.
