Results 1 to 12 of 12
    Apr 02 2016
    Rochdale
    Audi a4 fan running when engine is off
    Hi I have recently bought an audi a4 2.0 diesal 57 plate. Since buying the car once in a while when we switch of the engine the fan starts to spin. I have bought a replacement fan control module and fan and it does the same on that so I have returned it back to the seller. I've already had a flat battery once and I'm afraid it will happen again. Sometime if you turn the ignition and then lock the doors it doesn't spin it's hit and miss.
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    I think that's a symptom of your thermostat is bad? Could be wrong, but that's a place to look.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Feb 15 2016
    Cambridge,Ontario
    I think it is wired that the fan will come on regardless of ignition status if it detects engine temp too high
    Thermostat is definitely a possibility but I would put vag com on their and monitor engine coolant temp. if it is way out of whack it could be your engine coolant temp sensor. I don't know that engine and if there are separate sensors for the guage and fan switch however.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Apr 02 2016
    Rochdale
    Thankyou all I'm taking it back to the dealer next week. I'll see what he says.
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    I think all cars do that sometimes. Does it turn off after a few min? Are you in a hot climate?
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Thermostat
    2008 A4 S-line 2.0T
    JHM Stage 2
    Account Terminated Four Rings
    Oct 15 2013
    Quote Originally Posted by adam044 View Post
    i agree. there's nothing wrong with it. my old VW did it all the time. my audi doesn't get too hot very much.
    Veteran Member Four Rings brandonpham's Avatar
    Dec 07 2014
    Belleville, NJ
    Mine was Engine Coolant Temp sensor. That solved it for me. The one by the firewall on the coolant flange.
    Apr 02 2016
    Rochdale
    No it can go on for a long time that's what I initially thought
    Apr 02 2016
    Rochdale
    Quote Originally Posted by brandonpham View Post
    I thought it could be that. Apparently it can't be seen on the a4 diesal you can feel it if you put your hand down the back of the engine
    Apr 02 2016
    Rochdale
    No I'm in the uk
    Apr 02 2016
    Rochdale
    Dropped it off at the dealers this morning amd just rang him they have had to order a new module from audi and fit it in. Ouch that's going to cost a lot.
