Results 1 to 23 of 23
Thread: Dumbass mistake
    Established Member Two Rings alexb6t's Avatar
    Mar 11 2016
    quebec canada
    Dumbass mistake
    So here's the thing,
    my friend remplaced is cam chain tensioner on his 1.8t but now the car is running slighty bad(but it doesnt knock or anything it just not run well) Is there a way to check if he missed a theeth or something,where should we start ?
    Nov 10 2015
    Sudbury, ON
    grammar and punctuation go a long way.
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Mar 11 2016
    quebec canada
    Sorry stupid autocorrect + my english is not the greatest
    Sent from my SGH-I337M using Audizine mobile app
    Nov 10 2015
    Sudbury, ON
    So he replaced the timing chain upper guide? How many links between the gears?
    Mar 11 2016
    quebec canada
    No he replaced the binder,the guides and the chain but like the genius he is,he havent mark the gears
    Nov 10 2015
    Sudbury, ON
    What is the binder? Tensioner?
    Mar 11 2016
    quebec canada
    Yeah sorry
    Apr 07 2011
    There should be 16 links between.
    Yes sir. Crank mark at TDC and Cam mark at 12 o'clock (you have the valve cover off, so just make sure it is straight up and not down toward the ground (that would be "180 out"). Then look at the marks at the rear of the cams. This will confirm if your cam gear keyway is damaged or not. We are mainly interested in the exhaust cam mark, but the intake mark should be reasonably close to it's "arrow" as well.
    Mar 11 2016
    quebec canada
    I know but i think he turned the intake cam is there a way to check if it is in the right position
    Aug 26 2005
    Quote Originally Posted by alexb6t View Post
    With the timing belt alignment marks aligned at top dead center #1 piston, the exhaust cam 1st chain roller is offset 1/2 sprocket tooth toward the exhaust manifold from the vertical alignment of the cam bearing cap arrow, and the notch on the exhaust cam, and the 16th chain roller is vertically aligned with the intake cam bearing cap arrow and the notch on the intake cam.
    Vorsprung durch Technik
    Mar 11 2016
    quebec canada
    Problem solved those bolts where not torqued right ! thanks everyone
    Mar 11 2016
    quebec canada
    Can't see,maybe its because im on my phone ?
    Aug 26 2005
    Yeah maybe. PM sent.
    Senior Member Two Rings Captain_Panic's Avatar
    May 01 2015
    B6 A4T, VS800, C6 A6, Conversion Van
    Dublin, Ohio
    No, the links don't work. At least the problem was solved! Congrats OP!
    Aug 26 2005
    Quote Originally Posted by Captain_Panic View Post
    Image replaced.
    Aug 26 2005
    I am skeptical that the rough(?) running symptom could be caused by a loose cam bearing cap. That is inconsistent with the typical case.
    Mar 11 2016
    quebec canada
    They was not loose they was wayyy too tight
    Aug 26 2005
    OK, an over-tightened cam bearing cap would not cause the engine to run roughly or poorly. There must be something else involved.
    Mar 11 2016
    quebec canada
    It was only rough on idle... and that's the only thing i did.
    Aug 26 2005
    Alright. Regardless, there must have been something else causing the rough idle, that is now resolved somehow. No point in speculating for the actual cause further since it is only an academic matter now.
    Mar 11 2016
    quebec canada
    Yeah, thanks anyway !
    Dec 05 2007
    They are to be torqued to only 7 ft/lbs. It isn't much tq at all. I use the feeler method on this, because it is basically snug. But I have a fairly decent feeler.
    Going on assumption. If the caps were too too tight, then that also put extra strain on other parts such as your timing belt. You have a certain combustion at idle that isn't much. Basically just enough to drive the pistons and keep the engine running with no drivetrain load. Your belt had to work extra hard to move your cam. And to top that, you possibly could have (most likely did) scored your cam journals. Not saying that is what happened. All assumption.
    Jan 04 2014
    US
    any engine noise ?
    B6 04' A4 1.8TQ 6MT
