Results 1 to 8 of 8
    Feb 08 2016
    Freehold, NJ
    05 A4 B6 Part out leftovers
    2005 Audi A4 1.8T Automatic Quattro with 96k. Silver exterior with platinum gray interior. Major components sold off, still a decent amount of stuff lying around. Located Central Jersey 07726. Text 732-642-8107 for quick reply. Car fully stripped down, have pictures of everything. Thanks for looking!
    Leftovers:
    Headliner
    Dashboard
    Passenger Doors
    Carpet
    Heater Box
    Interior Trim set
    Accelerator & Bracket
    Brake Pedal
    Hood Release(grille latch)
    OEM Intercooler
    Motor Mounts
    Alternator/starter cable
    Air Intake Box
    MAF Sensor
    ABS Bracket
    Turbo Air Intake Duct Tube
    Front Backing Plates
    Throttlebody
    PRV Pipe
    Air Injection Pump Pipe Tube
    Vacuum Hose Line's
    Air Cleaner Vacuum Hard Line
    Metal Breather vacuum pipe
    Hood Release Cable
    Coolant Line
    Air Pump connector pipe
    EGR System Pipe
    Front Collision Sensors
    Brake Servo Vacuum
    EGR Breather Tube Pipe
    S-Bend Vacuum Pipe
    Front and Rear Seatbelts
    Brake booster & Master Cylinder
    Lower AC Line Hose Pipe
    Power steering cooler line
    Intercooler Air Duct
    Air Injection Pump Bracket
    Quattro Steering Fluid reservoir
    AC Drier
    Intercooler Mounting Bracket
    Engine Wiring Harness BRACKET
    Front Bumper Mounts/Shocks
    Intercooler Hose/ Turbo Coolant Line
    Plastic Fender body insert
    Heater Hose(Core to pipe)
    Air Intake Hose
    Plastic Cowl
    Driver Tail light
    ECU Box
    OEM Tool Set
    Lower Dash kickplate
    Trunk Anchors
    Trunk Shocks
    Steering Intermediate shaft
    Steering Column
    Cabin Air Filter Lower
    Front Sway Bar
    Front Auto Quattro Axles
    1.8T Engine Cover
    Rear Springs
    Rear Shocks
    Spare Tire Holder Screw
    Front License Plate Bracket
    OEM Jack
    Central Control Module
    Bose Amp
    XM Sat Receiver
    Passenger Airbag
    HVAC Controls
    Front Ashtray
    Sharkfin Antenna
    Antenna Booster
    Hazard Button
    Headlight Switch
    YAW Sensor
    TCM
    E-Brake Leather Handle
    E-Brake
    Airbag Module
    Cluster
    Clockspring
    Stock Speaker
    Rearview Mirror
    Wheel Airbag
    Window Motor Driver Rear
    Rear Seatbelt anchor(Thingy where you put the seatbelt in)
    Airducts(All of em!)
    Trunk Panel Trim
    Trunk Carpets(All of em!)
    Lil Door Lights
    Sun Sensor
    Sunvisor Lights
    Airvent Floor Grilles
    Rear Lock Switch(Center console)
    Emergency Trunk Release Handle
    Carpet Anchor
    Door Ashtray
    Rear Ashtray
    Shifter Assembly & Cable
    Sunroof Controls
    Center Console(plastic trim, not arm rest)
    Dead Pedal
    Bose Sub
    Hood/Trunk Hinges
    Gas Tank
    Driveshaft
    Sunroof Assembly
    Trans Cooler Lines
    Trunk Compartment box
    Whole Rear Assembly
    Veteran Member Three Rings mosnet99's Avatar
    Oct 10 2015
    2004 USP 1.8T, 1993 Jeep Cherokee Country
    Detroit, MI
    Secondary air injection pump?
    Sent from my LG-H811 using Tapatalk
    Misfiring 2004 1.8TQ USP, CX Racing FMIC, Hybrid K04, Milltek HFC
    Mar 27 2012
    1980 Harley Sportster
    Ocean city, nj
    Pretty sure I have a secondary air pump laying around. Pm me if he doesn't have one
    Sep 16 2010
    Central Wash
    I'd be interested in the 'plastic cowl' - if it's the thing in front of the windshield, covers the rain tray.
    And possibly the Central-Electrics module. 8E0 907 279 F
    Dec 19 2011
    Colorado Springs
    Under hood battery cover in good condition?
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    May 01 2014
    maryland
    pricing on passenger window regulator, tcm, stock speakers, bose amp and bose sub?
    also would you ship to MD?
    IG: S5Buzz
    Senior Member Two Rings alimo20's Avatar
    Jan 25 2011
    Philly
    interested in Power steering cooler line - the hard line coming from the block.
    i live in philly so i could stop by next week and take a look around in general
    Dec 19 2011
    Colorado Springs
    Stock Fuel hanger? Fuel basket
    Whatever you want to call it...the thing that houses the pump lol
