Results 1 to 30 of 30
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Boost gauge instal
    So i grabbed a cheap glowshift boost gauge for my car a few weeks ago. I dont want to buy a vent pod so im going to cut one of my vents and fit it in nicely. How do you guys get it to stay in place there though i dont want it to spin around or pop out. I want it to be pretty clean looking and like an oe finish.
    Active Member Two Rings NickSaieg's Avatar
    Nov 19 2015
    edison nj
    I traced the boost gauge onto the vent and then got some files. I kept test fitting till it was pretty tight. didn't use anything to tie it down and it still has yet to ever fall out. I used the middle left vent.
    Established Member Two Rings clause$'s Avatar
    Jan 26 2015
    Mammoth Lakes, CA
    Same here. Press fit. I bought some vents off eBay for cheap so it would be alright if I messed one up.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Epoxy. Then I painted the whole vent black.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    Remove the vent and put it in a drill press. Use 2" holesaw. Perfect fit.
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    Quote Originally Posted by Rodgman15 View Post
    Gah this would have made the job so much nicer, and look so much better.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Jan 12 2014
    Fargo, ND
    Used it in my aem afr gauge. I'm honestly surprised the vent didn't explode.
    Lean is mean!
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    It would probably be wise to build a little jig to do this as well. I've used this method twice and one time it ripped the vent out of my hand.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Jan 12 2014
    Fargo, ND
    Quote Originally Posted by Avant Nate View Post
    I have a vise on my drill press :)
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    16usd a nice tool to have if you have a drill press.. http://www.harborfreight.com/4-inch-...ise-30999.html
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Jan 12 2014
    Fargo, ND
    Quote Originally Posted by King_ View Post
    That's the one! Works great for the price. Certainly wouldn't use it on my big drill press, but works awesome on the smaller one!
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    did anyone ever tell you that just adding a boost gauge will in fact make your car slower?
    Quote Originally Posted by RagtagXMASTER View Post
    having a gauge jutting out your air vent is the look that all OE manufacturers are going for
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    A lot of good recomendations. Having the gauge is more for telling if the car is running right. Im having an issue were my car is falling on its face after 4k rpms.
    Senior Member Two Rings Spectre1130's Avatar
    Jan 08 2012
    2015 VW GTI
    Colorado Springs, CO
    I didn't want to cut my vents and did this.
    http://www.podi.ca/audi-b5-a4-s4-rs4-single-gauge-pod/
    97 A4 1.8t: Reflect 650cc, T3 6063 turbo, turbo back exhaust & FMIC, top mount manifold, Apex lowering springs, 81.5mm bore, Supertech pistons, Eagle H beams
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Never liked the column mount. Thought it looked ugly.
    Oct 09 2012
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Jan 12 2014
    Fargo, ND
    Such a clean install!!!
    Dec 13 2010
    FL
    Quote Originally Posted by king_ View Post
    z
    i
    p
    t
    i
    e
    Senior Member Three Rings Quattro420's Avatar
    Apr 08 2015
    2003 Jetta tdi 5peed 2000 b5 a4 1.8t 5aq, 2005 Passat tdi wagon2.0l, 2000 sierra 5.3l
    Ontario Canada
    Quattro it's a way of life
    Apr 03 2014
    17 GTI Sport
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Thought the same until I had one. Keeps all the gauges in one central location which I like. Had one on my B5 and bought another one when I got my B7 because I liked it enough.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Oct 09 2012
    Thanks, Always wanted it there.
    Quote Originally Posted by GrapeBandit View Post
    z
    i
    p
    t
    i
    e
    - - - Updated - - -
    Quote Originally Posted by adam044 View Post
    I never liked mine, always blocking shit.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Oct 31 2014
    NH
    - - - Updated - - -
    Not sure why you'd have shit in your car in the first place, use a toilet?
    2014 Audi S4 - 6MT
    2000 Audi A4
    Oct 09 2012
    By shit I mean the instrument cluster Christmas lights.
    Sent from my Jailbroken iPhone 6s 9.0.2 using Tapashit
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Veteran Member Three Rings PringlesInVic's Avatar
    Oct 31 2015
    '05 Touareg V8, '11 MkVI Jetta TDI
    Victoria, BC
    I love my column mount gauge from Podi, way more OEM than a vent.
    SOLD - '98.5 A4 1.8TQM - Aluminum Silver Metalic
    REVO Stage 1 - BW K04 - CTS Test Pipe - Milltek Exhaust - ST Coilovers - Hyperboost DV - ECS Snub - TFSI Coils/ICM Delete - eBay SS - Valeo SFW - DEPO Ecodes - 18" BBS Reps - OEM RS4 Grille - Alpine/Hertz Stereo - PODI Boost Gauge + POD
    Build Thread HERE
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    I have afr on a column pod and boost in the left vent. Hate the vent pod. It looks meh imo and it reflects off the glass right where the side mirror is. I'm going to be buying a dual column pod at some point but they are pretty expensive.
    Dec 13 2010
    FL
    i know my custom one-off is not everyones cup of tea, but being who I am, i like to think outside the box and make my own things whenever possible
    Nov 27 2010
    mass
    That's actually pretty cool. Obviously you left the drivers vent for comfort but personally I would have put the gauges on the drivers side of those 3. Did that make sense? Haha
    Dec 13 2010
    FL
    Quote Originally Posted by ray4624 View Post
    tnx, and i do prefer to have the vent blowing on me, screw the passengers
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Got that gauge all done the vent buldges a little but if it really bothers me i guess ill trim it in a little better
