Results 1 to 6 of 6
    Jan 27 2016
    Bulgaria
    Audi A6 C5 4.2 V8 Wide tyre install
    I need to change my summer tyres and I am in love with wide wheels. Right now the car is with stock "Fat five" alloy wheels - 255/40/17. What I am thinking of is 285/40/17. :) Would they be too wide?
    Maybe spacers will do the work if I buy 255 (15mm front and 20mm rear)? The car is with stock suspention.
    Veteran Member Three Rings JediJoker7169's Avatar
    Dec 11 2009
    PDX, OR/SF Bay Area, CA - USA
    They'll be too tall, a full 1" taller. Also, this is totally a question for general discussion; doesn't need to be here in the chatterbox.
    - JediJoker
    "Dieselgate" / 2011 VW Jetta SportWagen TDI 6-speed
    FORMER: "Das Boot" / 2001 Audi A6 2.7T quattro sedan:
    RS4 clutch / 710N DVs / 2Bennett Stage2 GT front 6-piston Brembo 350mm/rear 311mm / Bilstein PSS9 / Hotchkis Sport anti-roll bars / 034 Density adjustable front UCAs/Track Density front shock mounts/spherical ARB end links / O.Z. Superturismo LM 18" x 8" / Hella E-codes / LED tails / Facelift rear license plate trim
    Jan 27 2016
    Bulgaria
    Thank you for the helpful answer! Will know from now on.
    Jan 19 2014
    b5 a4 1.8tq
    New York
    i doubt 285 40 17 will fit on an 8 inch wide wheel. Even at a tire shop, they will say 255 40 17 is too big for a 17x8 wheel
    Veteran Member Four Rings A4edwin's Avatar
    Dec 07 2008
    01 a6 4.2 sport, 92vw cabriolet, 03 Tahoe, 03 Ford Explorer sport.
    New York
    255/40 is stock size for the 17x8 fat fives. You're going to need a wider rim for that size tire.
    unitronic tune, milltek exhaust, Avant garde m590 wheels 19x9.5 e.t. 40, sumitomo tires 255/35/19 tires, h&r coilovers, ecs 12.5-15mm spacers, ecs slotted rotors, pbr pads, "oem allweather mats" <
    Aug 04 2009
    Glen Ellyn, IL
    255 is out of manufacturer spec for most brands, but you could stuff it on an 8" wheel. If you get a 'normal' street tire you should run a higher PSI to avoid some of the impending sidewall rollover.
    For a 285 you'd need a 9.5" wide wheel. If you're married to the fat fives you can get them widened to 9.5 and put 285s on, but I don't think those would fit in the arches without modification beyond rolling.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
