Results 1 to 26 of 26
Thread: Timing Belt
    Established Member Two Rings Forge04's Avatar
    Mar 20 2016
    2007 Audi A4 2.0T FWD 2009 Chevrolet Avalanche LTZ PAST: 1979 IH Scout II 1971 IH Scout II
    Middleton, ID
    Timing Belt
    So, here's some backstory real quick: I'm going to become a college student here in the fall. My B7 was just purchased and I'm nervous about the Timing Belt, the oil, the cam follower and the CVT. I've had the CVT drained and refilled, the shop said the fluid looked great, so I'm confident in my transmission. I have a new follower to put in, just need the time.
    But the timing belt...
    I'm currently at 90,7~~ miles. But I have a friend that worked at a VW dealer say it's not nessessary until at least 100K, and others here are saying the same. The kit, the way I have it at a budget set up, from Europa is $270, plus I'd need fluids and the like.
    So I'm worried that if I don't do the timing belt now, later when I need to do it I won't have the funds.
    That said, I believe I could use a new snub mount, just cause, and I'd really like a new radio unit...
    So, any advise? Timing belt now or later?
    TIA
    2007 B7 A4 with 2.0T FWD
    May 20 2014
    e92
    Timing belt now.
    You will be sitting pretty with your new radio and snub mount if the belt decides to snap. Snub mount is cheap, do it when you do timing belt. If you shop around you will be able to fit it under your budget. Buy different parts from different vendors if you don't mind spending an hour cross shopping with part numbers. Most vendors have free shipping upwards of some fixed amount. So plan accordingly and make use of it to spend the least and still get good parts. That's what college students do. Lol.
    Mar 20 2016
    Middleton, ID
    Of course the radio is of a crazy amount of nonimportance when stacked up to the other stuff. I was just going to go with the urethane snub from Europa.
    Trj you seem pretty solid on the timing belt now. I understand the importance of doing it before it fails, but why the urgency? How often do they actually fail before 100K?
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Quote Originally Posted by Forge04 View Post
    How? THIS is how.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    .....If you've got the money to do it now... Uh do it?
    Audi service manual says 110k, I'm at 95k right now. I'm going to get it done next summer, I'll be riding the bike a lot in the summer so I'll probably be right around 100k next summer, maybe a little more.
    Want a JHM tune this summer.
    May 20 2014
    e92
    It's all good till it breaks. It's not just the belt. It's the thermostat, waterpump and pulleys too. I did it at 85k just to be safe. Any one of it can fail at that many miles. You never know, you might get 150k out of it. But it's not like a bulb where you change it only when it fails.
    It's my daily driver so I don't want it to be in the shop because of negligence. That's about it. Nothing against waiting or changing at 60k miles. To put it into perspective, I have stock symphony ii radio and non sports suspension. But I am sure those two will not keep me off the road, but a broken timing belt will.
    I don't want to invest in this car, but want it to run without any problems till I sell it.
    Mar 20 2016
    Middleton, ID
    As do I. Same exact situation. I Uber with this car, and honestly, it pays for itself, at least payment wise. I'm hoping to use Uber as well to get that recommended $1500 in the bank just in case as well.
    Thanks for the advise, everyone. Really.
    Oct 31 2014
    NH
    Quote Originally Posted by trj View Post
    Sell it now and run far far away then
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Feb 15 2016
    Cambridge,Ontario
    Anyone sitting in the 90k range with the original belt is gambling, no question. It's not just milage..these belts are 10 years old now.
    Every family has a different situation. I just bought the same car for my son to go to college. He and I will be changing the belt together as he wants to learn and I offered to fund it. To be fair I have done 4 timing belts on Audis.
    Bottom line is get it changed asap. Better 12 months early than 5 seconds too late.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 08 2012
    Dallas, GA
    This. ^^^
    Just do it now. Especially if you're doing the work yourself. It's a whole lot cheaper than new valves and a head rebuild (if you're that lucky). Also, the Audi dealership AND my indie shop both said the interval was adjusted down to 75k miles in the last couple years. I know not everyone is being told that, but hearing it from two different sources, I went ahead and did it at about 8 yrs/80k miles.
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    Allow me to add to the excellent advice to change it now. How long do you plan on owning the car? If it is at least 20k more miles and less than another 120K miles you will undoubtedly will be changing the belt only once on this car. So it makes perfect sense to do it now (unless you really want to experience the consequences of a failed belt). The car will run just fine without a radio upgrade, and as stated above the snub is a relatively inexpensive proposition.
    Brillo
    Nov 21 2014
    Montreal
    Just open the timing belt cover and inspect it, takes less than 5 minutes. Then depending on the cracks, decide if you need to change it or not.
    Feb 15 2016
    Cambridge,Ontario
    I have seen perfectly good looking belts snapped .. just my 2c.
    1976 Yamaha XS 360
    Active Member One Ring zagimon's Avatar
    Feb 15 2016
    A4 2008 Audi A4 quatro S-line : Mercedes 2012 C250
    dallas,tx
    Mine went to 107k. Went with the Europa kit. Good kit for the price.
    Feb 15 2016
    dallas,tx
    What about the rollers and tensioner? Can't really inspect that.
    Oct 02 2006
    Wadsworth,OH
    When you do a timing belt service you want to replace all the components as well. We have complete kits available for your B7 2.0T to get the job done. As well as a step by step installation PDF.
    Check out our -----> Installation PDF <-----
    Jason
    May 20 2014
    e92
    Quote Originally Posted by adam044 View Post
    Lol. You get me wrong my friend. I dont dislike the car. I just dont want to spend my time and effort modding this car. I am not new to german cars, I know exactly how much its worth to spend in this car. By the time I mod it to get it to the stage I want, I will have spent more money than on a S4. So, I am not modding it, maintenance is another question. I am not skipping any maintenance. All fluids changed, all maintenance work done by myself. Everything that needs to be replaced has been replaced from brakes, fluids, DV, n80, cam follower, belts to bulbs. There is nothing about selling it now or in 10 years. As a DD, I want it to perform flawlessly, but as a modded car, it will never become what I want it to be. I have already retrofitted the creature comforts I wanted in this car. Bixenons, auto dim mirrors, power folding mirrors, memory mirrors, memory seats, auto dip on reverse passenger side mirror, RS4 rear sway bar, snub mount all have been done. I spent a good one year on research and gathering required parts for the retrofits and maintenance. If I sell the car, the next owner will be a happy one, I can guarantee it. But yah, I am not going to build the engine, put big turbo, put a tune in it. Thats what I meant by investing till I sell it.
    Senior Member Two Rings UberTeile's Avatar
    Sep 01 2010
    Southeastern, PA
    I just had mine replaced last weekend @ 94k miles. I purchased the parts from FCPEuro.com. Upon visual inspection, my original TB really wasn't in horrible shape...but, obviously, it had to be replaced due to age.
    ll Audi Sport "Vorsprung Durch Technik"
    Jan 24 2013
    Chicago
    I got mine off ebay. Reputable seller, quality parts. Coolant can be purchased from the dealer for $20/gal undiluted. LINK
    Oct 31 2014
    NH
    Quote Originally Posted by Denio24 View Post
    I wouldn't even take that for free.
    Coolant from the dealer is already mixed, just pour.
    Jan 24 2013
    Chicago
    Can't tell if you're trolling or just not informed. G013A8J1G comes undiluted, and the ebay link comes with all quality parts (ina, continental, etc.)
    Oct 31 2014
    NH
    Didn't click link sorry.
    Idk what that is but G12 coolant is already mixed. Aka coolant from the dealer.
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Im going to go with ill informed, considering he thinks G12 is pre mixed
    2008 A4 S-line 2.0T
    JHM Stage 2
    Jan 24 2013
    Chicago
    Isnt it like g13+ now?
    Sent from my SM-G920P using Tapatalk
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Yup
    2008 A4 S-line 2.0T
    JHM Stage 2
    Mar 20 2016
    Middleton, ID
    Pulled it in on the 22nd, and took the better part of a day. Sounds stupid but the two rotations to even out the tension killed us for like an hour lol.
    But alas, it is done. And now I can rest easy, on that front anyway.
