Results 1 to 13 of 13
    Jul 24 2014
    '02 Audi a4, '87 bmw 325i cabriolet, '93 bmw 318is coupe, '98 a4 quattro 1.8t
    Denver
    Lightbulb Washing engine/under
    Hi! I've been having oil leaks which I have now found the issue for. The whole bottom of my car is oily and I would like to wash it. Can i get a pressure washer and just pressure wash the whole bottom of the car? I also would like to wash my engine and need some advice. I've read a lot of different stories online so can someone please give me advice. Thanks
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Ive washed my engine with a pressure washer with no problems. Might have gotten lucky with the electrics
    Established Member Two Rings cclarkb5's Avatar
    Feb 02 2015
    1991 Audi 90 20v
    Bellingham, Washington
    I prefer simple green spray with delicate stuff but pressure wash probably isn't a bad idea for the underside
    They last long if you treat them any better than totally shitty. | 1999.5 2.8QA Volcano Black Mica | 1991 90 20vQM Pearl White |
    Jul 24 2014
    Denver
    Quote Originally Posted by cclarkb5 View Post
    okay. and what precautions should I do before?
    Apr 17 2012
    2001 Audi A4 1.8t Quattro; 1994 Jeep Grand Cherokee 5.2l
    Red Deer, Alberta
    I pop the hood, wrap grocery bags over everything I don't want water in/on spray on full strength degreaser, then use just a garden hose to rinse, comes spotless, use a 1" paintbrush to break up and loosen where it's worst and it will shine, make sure you put a bag over the electrical connections going through firewall etc and alternator. Mine fell off last time and o had two days without a speedometer till fully dried out
    Jul 24 2014
    Denver
    Quote Originally Posted by davyboy View Post
    electronics haha. I used to have a subaru and i'd just pressure wash the whole shit. my engine is heavily dirty and greasy. Whats a product you'd prefer the best
    Veteran Member Four Rings pbcrazy's Avatar
    Feb 06 2013
    VA
    You can, but I wouldn't. I use WD-40 engine degreaser, you just spray it on, scrub the bad spots, then gently wash it off or use a towel. IMO worth an extra few minutes to make sure you don't screw up something
    98.5 Audi A4 1.8T Quattro | 5 Speed | AEB | Laser Red
    | FrankenTurbo F21L | United Motorsports Stage 3 | 630cc Injectors | 3" MAF | ICM Delete w/FSI Coils | Scorpion 2.5" Catback/RAI 3" Test Pipe | Forge 007 | 034 Silicone PCV | Alzor 349 | FMIC | ECS RA4 LWFW/S4 Clutch/S4 P.Plate | AEM | Krauto | etc.
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    When i pressure washed i tried to use the widest spray nozel low pressure and avoid wires to not break them. I then air dried everything with an air compressor and blow gun to remove water from key electrical areas
    Veteran Member Three Rings b5a4erik's Avatar
    Apr 22 2014
    Aptos, CA
    I've heard pressure washing can be dangerous for seals n such...
    I'd go engine degreaser all around then a standard hose sprayer.
    Feb 06 2013
    VA
    Quote Originally Posted by b5a4erik View Post
    It should be fine like all the people online yell about, engines are waterproof'd (for the most part) from the factory.......17 years ago. Vacuum lines dry rot, seals start to let shit in, you might even have a cracked pcv, in which case high pressure water is not a good idea which most people don't seem to understand
    Apr 22 2014
    Aptos, CA
    Quote Originally Posted by pbcrazy View Post
    Veteran Member Three Rings Sumo337's Avatar
    Jan 07 2015
    2011 B8S4
    Pittsburgh, PA
    So far, I never sprayed water on it. I just use spray cleaning bottles. I live in Pittsburgh, and the sheetz car wash has bottom sprayers that cleans the whole under the car, from front to back. Pretty sleek.
    @chetbagged
    2011 B8S4 Prestige
    460HP-384TQ Manual
    APR / ECS / P3 / WCI / Sportshifters / Polo Performance / Airlift / Caractere
    Veteran Member Three Rings Thumper3's Avatar
    Nov 27 2014
    1983 Porsche 944
    Missouri
    What people also don't realize is that engine bay "water proofing" is designed for rain spray, etc.....not submerging or hitting an electrical cover with 1500 PSI water. It's like complaining that your "water-tight" windows on your house didn't standup to the Class 5 hurricane. LMAO
    '23 A4 Allroad Prestige | District Green | Black Optics | 034 Dynamic+ Springs
    '18 TTRS - Mexico Blue | APR Stg 1 e85/TCU Tune | RSe10 Bronze | Girodisc rotors front/Neuspeed 350mm Rears | Black Optics/Sport Exhaust | Red Calipers | Red Stitching
    '14 VW Touareg TDI R-Line - White | Euro paddle shift
    '12 VW Golf R - White | Stg 3 APR | Too much to list here
