Results 1 to 12 of 12
    Sep 17 2015
    United States
    license plate lightning
    my A4 B6 3.0 license lightning are both broken off. the question now is : 1/ should I replace it with oem and buy LED bulb for it or 2) should I just buy an LED replacement for it? does the LED replacement fit directly, snuggly on it ? any recommendation?
    Olivier
    Apr 13 2009
    NS
    I bought the compete led light replacements for mine and they work great ! Found them on Amazon for a great price. And no error lights either M
    Sep 17 2015
    United States
    who do you buy it from? i see a few on amazon but i asked people there, some of them say they won't fit in properly i.e. the latch won't latched.
    Mar 02 2015
    miami
    i got mine from ebay. i had to go to ace hardware to get a longer screw but besides that no problems 6 months later and vry bright, not blue either.
    http://www.ebay.com/itm/1-Set-USA-Xe...QAAOSw3ydVqxw9
    i think i offered him 13 or 14 bucks and he took it. probably can get a little cheaper from china but hes a usa seller so itll get to u in a few days vs a few weeks.
    then just take one of the screws to the hardware store and find one a hair longer and install.
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    If you're going to replace the lights, you absolutely need to have the mounting screws in all the way, or else the lights wont work. I couldn't get the screws back in far enough and the contacts were in rough shape anyways. $75 at shokan got me the whole assembly used that looks brand new with the lights already installed.
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    Mar 02 2015
    miami
    hence why i got longer screws. its an aftermarket part for cheap so u cant expect perfection. the screw hole where the head of the screw sits was a hair too small. fix this by either grinding the hole a little bigger to fit the head or get a longer screw. i live in miami where it rains all the time and has like 100% humidy, no leaks, no fogging up, no errors, nothing.
    im poor so i try to use the most budget friendly parts. just an option. spend 75 on license plate lights if you want lol.
    Oct 02 2006
    Wadsworth,OH
    We have complete LED license plate assemblies available below!
    Jason
    Mar 02 2015
    miami
    ecs always another good option.
    Sep 17 2015
    United States
    I bought the one from amazon and it does not fit/seat into the well very good.
    the clip with red highlight does not seat into the cut of the light well. if i push the light and get the clip seat in the light well, then the blue high light will miss the install hole. this is the XJDM light from amazon with 22 reviews and they said it work on A4 B6 but not in my case.
    May 21 2013
    Milwaukee
    OEM Q5 lights are the best choice IMO
    Senior Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5
    LI, NY
    To address the seating issue that some of you are talking about. Usually the mounting point is all corroded and dirty. If you clean out the edges where the light is supposed to clip into you shouldnt have any fitment issues.
    14 B8.5 S4 6MT Current Daily
    01.5 B5 S4 6MT SOLD
    04 C5 A6 2.7T S-line SOLD
    02 B6 A4 1.8TQM DG Sport Package SOLD
    Motoza Stage 2, USP front end conversion w/ Cupra lip, S4 rear bumper, 18" BBS CH, OBX catback exhaust, Genesis 380cc injectors, PSI concepts test pipe, Stratmosphere Hyperboost DV, CX Racing FMIC, Forge TIP, S4 BBK, etc...
    Sep 17 2015
    United States
    i took my out and sand blasting it, then prime it, then repainting it. there is no corrosion nor etc.
