Results 1 to 18 of 18
Thread: Wheel size
Hybrid View
    Veteran Member Three Rings VeNoMS4's Avatar
    Feb 02 2016
    Peoria, Arizona
    Thumbs up Wheel size
    Hi guys,
    looking to install 19x9.5" wheels in the back of my 11' S4. What size wheels can be put up front that wont cause any problems. I just think 19x9.5 up front is too wide or is that actually normal? Will lower car by roughly 1.5" with H&R sport lowering springs.
    Registered User Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    Check the wheel fitment discussion, but for reference a 19x9.5 et40 will sit just about perfect all around with no rubbing with a 255 35 19 tire lowered.
    Sent from my VS986 using Tapatalk
    Feb 02 2016
    Peoria, Arizona
    Quote Originally Posted by jbullin2 View Post
    If you did this setup to your s4, when you changed the springs did you also change shocks and struts?
    Sent from my LG-H811 using Tapatalk
    2011 S4 -Ibis White // GIAC Stage I // GIAC DSG tune // AWE Track Cat back // Injen SP Intake // VMR V710 19x9.5 //
    Senior Member Three Rings AudiSTL's Avatar
    Sep 21 2013
    2011 S4
    st. louis
    19x9.5 et 40 is a perfect setup for a s4 imo with a 255/35 tire am running 19x10 et35 with 245/35 tire slight stretch and its perfect for me
    AWE Quad Exhaust / Rotifom Ind 19x10 (old) / V12 245/35 tires / Solo Werks / ECS Carbon Luft Intake / Stoptech / Verde V99 19x9.5
    Enlaes CF decklid / EPL 1+ w DSG
    https://www.instagram.com/admirstl3/
    Dec 21 2014
    Milwaukee
    Quote Originally Posted by VeNoMS4 View Post
    Yes. Did H&R Sport springs with Bilstein Sport shocks.
    Feb 02 2016
    Peoria, Arizona
    Was it a cup kit? Don't the shocks and struts not come with the mounts? Used donor mounts? How's the ride?
    Dec 21 2014
    Milwaukee
    Look up the shocks on ECS. It shows you everything that comes with them. You don't need anything extra. The fronts are struts with the spring perch. The rears are separate shocks/springs so just standalone shock tubes in back.
    Ride was very close to stock with this setup. Was very pleased with it.
    Nov 23 2014
    North Carolina
    offset is more of the concern. then tire width. something like an ET45 in 19x9.5 flavor is just fine, even when moderately lowered. the question is just how low and what tire. to my understanding 255/35-19 will work in the majority of cases but since some tires are wider than others you MAY need to roll the inner fender in some cases depending on how low you go. I've run et45 9.5" for my winter set and it worked fine, but I also had a 245 tire width in that situation and not lowered. looking at it, I think lowering would have been fine, but going 1.5" lower and with something like michelin PSS tires it'd be close. anything with less ET would be asking to rub.
    Jran may chime in, he has quite a knowledge base on this topic
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Dec 21 2014
    Milwaukee
    Nov 28 2015
    Montreal, QC
    ^^ thats the 9.5 + 40 ?
    Nov 23 2014
    North Carolina
    maybe an optical illusion? it looks less flush than my ET45 on the front
    2019 X3 M40i - Sold
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by torinalth View Post
    He's pretty low and has quite a bit of negative camber. That's always going to look a little more tucked in.
    9.5" is fine all the way around if you are lowered. I'd definitely go that route before I ran staggered wheels/tires. With the 255/35/19 tire, an ET40 is relatively safe. If you want to be 100% safe, you can go a few mm's higher. As mentioned, a lot will depend on the tires, ride height, and alignment.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Veteran Member Four Rings mojangles69's Avatar
    Jun 03 2013
    2022 BMW X3 M Comp / 2017 Porsche 911 S / 2008 Audi A6 3.2 Wagon / Magic Carpet / Camel / Donkey
    Charlotte / North Carolina
    Quote Originally Posted by jran76 View Post
    Yes to both above.
    I run 19x9.5" with 40 offset all around. Currently wrapped in DWS 06 all-season tires 255/35/19. These are much meatier than the stock Conti's that came on the car. No issues at all. About 25.3" fender to ground all around as well. Some very slight rubbing on big dips in highway on passenger rear side when gas tank is half-full to full.
    Do NOT run staggered setup on Quattro...only complicates things and can potentially be very damaging to the drivetrain. I'm sure Jran can provide more specific and accurate info but, in general, not advised to do staggered setups on all wheel drive vehicles.
    IMO - 19x9.5 is the best setup for our platform, blend of practicality and aesthetics. Nice wide stance and fills wheel well nicely.
    2017 RS7 Performance - Sepang Blue - Performance Design Selection Package w/ Mercato Blue stitching and blue twill in interior carbon fiber components - APR Stage 2 w/ Militek downpipes and exhaust - Aquamist Methanol Kit - Custom Roc-Euro Intake - KW Adjustable coilover springs - K40 Radar/Laser System
    XPEL Ultimate, Ceramic Pro & Apex Huper Optik window tint
    IG
    Oct 31 2013
    Morris County, NJ
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Nov 28 2015
    Montreal, QC
    willtheyfit.com is a good tool.
    a 19x 9.5 et40 will poke 15.7mm more than OEM. Seems like a common match on the forum with no issue. I'm going 18x9 +30 which poke 19.4mm. i'm not dropped so it should be good.
    Feb 02 2016
    Peoria, Arizona
    ok it's done then. Right now my wheels are i believe the stock 18x8.5 .. im going to a square setup with 19x9.5. as for tires, right now im running the hankook venti.. something..something...something 245/40. The plan was to drop by 1.5" and if that wont happen without rolling fenders, i'll just do 1.25". as for the offset, i was going to go with et43 or 45 so it wont be a problem. but i see some of you guys are running lower than that.
    thanks for the tips guys. much appreciated.
    Feb 28 2012
    Hopes and Dreams
    Miami, FL
    I'm 10" + 36 all around
    '14 S4 DSG (Ibis White)
    BC Racing Type BR Coilovers | Vossen VFS1 19x10 ET36 | Zeus Flash ECU & TCU Flash | Corsa Performance RSC Exhaust
    Freelance Photographer
    State of Stance | Brand Director
    [email protected]
