Results 1 to 12 of 12
    Senior Member Two Rings junxing's Avatar
    May 12 2010
    Chesapeake, VA
    Black B7 Center Console with armrest and e-brake handle
    SOLD
    Black B7 center console in excellent condition, with B7 e-brake handle, B7 armrest and the longer bolt for the e-brake handle. Everything you need to install the B7 center console into your B6 is included, the wiring harness for the 12v outlet has been modified to fit the B6 wiring. The only issue is that the latch for the armrest is broken.
    2003 Audi A4 3.0 Avant quattro Atlas Gray/Platinum Gray/6SPD
    -VAG-COM available in the Hampton Roads area
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    Great price! and such an awesome upgrade for the B6.
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Veteran Member Three Rings mosnet99's Avatar
    Oct 10 2015
    2004 USP 1.8T, 1993 Jeep Cherokee Country
    Detroit, MI
    Quote Originally Posted by junxing View Post
    Asking $200 + shipping + fees
    Located in Chesapeake, VA; local pick-up welcome.
    Is this a direct bolt on for the b6? Like no retrofitting??
    Sent from my LG-H811 using Tapatalk
    Misfiring 2004 1.8TQ USP, CX Racing FMIC, Hybrid K04, Milltek HFC
    Dec 17 2009
    Kentucky
    The set up in this ad will only require to remove the ebrake boot from your B6 ebrake assembly and put on the to the provided B7 one. There may be some modification to the boot required as they are a bit different.
    The rest is bolt on and a matter of extending the wires for the 12v power outlet.
    Oct 10 2015
    Detroit, MI
    Quote Originally Posted by MurkyRivers_A4 View Post
    Okay I just would rather not deal with the modding of the ebrake lever. Are you saying its a chance the b6 or the b7 boot won't work without modification to it when installing in a b6? (sorry ran across a couple deals where I got into more than I bargained 4)
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Use the B7 ebrake and B7 boot for this swap. B7 boot fits fine
    Apr 25 2014
    Downey, CA
    No shipping?
    Sent from my SM-G930T using Tapatalk
    Using Tapatalk
    Oct 10 2015
    Detroit, MI
    PM sent
    May 12 2010
    Chesapeake, VA
    The B7 e-brake boot is included, it's just sitting in the console instead of the e-brake handle. And the 12v outlet has been wired up to fit the B6 wiring. I can ship but it'll probably be expensive because of how bulky it it.
    Dec 17 2009
    Kentucky
    Oh shit, i didnt even see it in there lol.
    Probably the best package ive seen then.
    Active Member Three Rings
    Feb 10 2015
    seattle
    Pm'd
    Veteran Member Three Rings cmiguel32's Avatar
    Aug 13 2007
    2003 A4 / 2014 S4 / 2017 Q5
    NC
    Sold to moi.
    Chris
    B6 A4: 2.0 stroker, IE cams, JHM 01E/Stg4 RS4 clutch/FW, SEM manifold, EFR7163, Motoza, ID1050x, Walbro 450, Garrett FMIC, 034 mounts/RSB, Koni coils, Hotchkis FSB, 18z, VFIZ, etc.
    B8.5 S4: EPL DP 57/187 (E40), 75mm TB, Ported SC, Meth, Autotech HPFP, Killer Chiller, Borla Exhaust, Merc HX, JHM SS/3R/Race pipes, Eurocode Sway, 034 springs, CR15
    429 whp/431 wtq 93 oct (stock TB)
    Insta: QuattroNC
