One day I go out to start the car and it sounds terrible like it is missing on a cylinder. I run the car home and pull the codes and see the P0303 Cylinder 3 misfire. I swapped coil and plug from #2 to #3 and the code came back STILL on #3 but I swapped out the coil anyways on #3. The car felt better however the problem came back with what feels like a failure to spool on the high end and a bad stumble at idle speed. Also when I get up to higher RPMs I can tell the car is not producing the power and it frequently goes into limp mode with the CEL constant on. So since I replaced the plugs and coil my next thought was a clogged injector. I then began a concerted effort to clear out that injector using fuel injector cleaners. I ran a couple tanks of gas and 3 or 4 bottle of fuel injector including 30 oz of Techron through the system. No changes so I went ahead and bought all 4 new fuel injectors and pulled the intake manifold off and swapped out all the injectors and changed out the fuel filter with the Mann one. Reset all the codes and the same issue exists. What else could it be? There are no other codes except #3 misfire. I use my bluetooth OBD2 and my phone to reset the codes to get out of limp mode when I drive but this can't go on forever. When I looked at the valves they looked a little caked up but not clogged by any means.
What's next here for me to try? Thanks for any help here!
