Just seeing if anyone can point me in the right direction in my search for a vacuum leak.
Symptoms:
When I start the engine, it will hold usually anywhere from 10-17hg in vacuum (depending on how long it's been sitting). As I get onto the throttle and it moves towards zero, the number never climbs back up. For example, if it's sitting at 15hg and I give some gas and vacuum drops to 11hg, it does not climb back to 15 when I release and will stay at 11. This is true down to the 5-10hg range depending on the day. If I get into boost, it might settle immediately back to 6hg and then slowly climb back to 7 then 8 then 9.
Because of this I'm inclined to think it's a check valve or something of the sort. Has anybody else experienced this? I have done a visual inspection of vacuum lines, but do not have access to a smoke tester.
