So I took some time to treat my leather and interior yesterday, then I did an engine bay detail.
Then I decided to clean my k&n drop in and things got a little out of hand .
I decided I wanted to figure out a little better free flowing intake without spending a ton of money and without doing anything irreversable.
First let me say that on an intercooler car I do not believe in CAI. Your intercoolers can only get the iat to a certain temp(ambient), regardless of the air they are pulling through, unless that air is ridiculously hot, then they will heat soak. Or you have an intercooler Mister, using water or a high flash point alcohol, such as methanol. In short a CAI is a waste if you're buying it just for cooling purposes, and you are intercooled.
On to the business...
I removed the stock air box, cleaned it up, then I remembered that I had an old air raid filter from a truck. I pulled it out, cleaned it up and it ended up being a perfect fit for my idea. I wanted to keep the stock under-hood air scoop, to bring fresh cool air to the filter, and I needed a heat shield so I grabbed the one off the old air box, it fit perfectly. I put two slight notches on the old air box shell and pressed the heat shield in to them, I then slightly bent the heat shield to fit right over the manifold. I took this for a spirited drive and it never came loose or fell off. So I think I have a winning design. Everything is reversible back to stock. And you'd never know it was messed with. Which is what I wanted. If anyone wants the part number for this filter let me know. I will be posting pictures shortly.
