Originally Posted by
Gmoney1147
Drop rear subframe for the rear so much easier. 4 bolts done. Make sure you have a jack under rear diff so when the subframe is undone it doesn't fall fast
I would agree, dropping the subframe adds a bit more time, but makings installing the springs much easier.
Gmoney1147
Why are you even buying those?
You need to get a set of spring compressors like these:
From personal experience, when you're "guesstimating" the high you want to set the coils at, it's better to set them HIGHER than lower. Why? Because if they are too low, you'll be fighting the weight of the vehicle and compression of the spring when you're trying to spin the coils up, as opposed to down. Trust me on this.
Make sure you also have a front strut knuckle spreader.
