    Jan 24 2010
    Paramus,NJ USA
    Automatic to manual???
    So I have a b6 a4 1.8T manual car engine is shot to shit.I have a awm engine that came out of a automatic Passat b5.5. I have read different things some says automatic could be converted to manual by pressing in the pilot bearing other says not possible.Anyone know for sure???
    Ziddy Autowerks
    Apr 07 2011
    AFAIK the autos have a different crankshaft than the manuals. The CVT is an exception. I believe I've read there's a way to make it work but it requires modification to the crankshaft.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    It is relatively simple. You use a slide hammer to pull a bushing out of the end of the crank.
    Get a 2.8 pilot bearing. Cut the closed end of it off and install the bearing with the cut end out. Only install it about half way.
    That is it.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Jan 24 2010
    Paramus,NJ USA
    Thanks redline!!
    Ziddy Autowerks
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    My best mod I have done!!!! Love my 6 speed. Do it!!!!
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
