I currently have had the transmission flushed, cv boots taken care of, ball joints done if needed, and yes there is fucking soda spilled all over the hvac and radio controls, oil change, coolant flush.
I have no information on if the turbos or timing belt has ever been replaced.
Burns oil so gaskets for sure, shocks are good, one cracked spring, i think i hear one wheel bearing, LCD is shit, Dont believe i have any boost leak I hold just over 9 psi on full load. and no fluctuation.
Checked the controllers. i have no connection issue between each individual one but when i read the ecu it says missing message from the tcm and when i connect to the tcm it says missing message from ecu.
So I should probably check the wiring between the ecu and tcm???
