I keep hearing that the block came with 3 different bore diameters from factory, they then matched the pistons to each cylinder ...
Make long story short, i got stuck with a problem car, the previous owner cracked a rod a some point, paid a shop to change everything on the car (complete chain guides , clutch , mounts, etc..)
BUT, they decided to gamble with a gauge on the lower part of the cylinder, which ultimate means the rebuild failed and they dumped the car, this happened a couple of times till it ended up in my hands wholesale (im in the business)....
Im now looking at the most ridicules build i have ever seen, there is silicone everywhere, compression was fine when i pulled it, but something was def wrong, burning major oil, power was off...
They ended up sticking a ford auto light in the problem cylinder and pushing it away...
I have a large shop with skilled guys, but this might be the breaking point car... ha
I am going to recondition the alyusil block, and re ring... The Porsche guys do this frequently but i don't see much of it in these forums...
im now faced with the problem of rods and piston.... i wanted to go with scat rods, but it looks like they will not fit on the stock pistons...
Do i really feel like dumping 4k into rods and custom pistons on a problem platform... I keep Reading that the piston expansion is the major issue causing this scoring..... which makes me reluctant to throw more money into having something flawed in the end... if the stock pistons and rods go, then so be it... am i wrong?
Will the salvageable pistons from og block fit into the new/er block.... or is there size discrepancy from factory...
Yes that was long..
