Results 1 to 10 of 10
Thread: 3 fault codes
    Junior Member One Ring Kwakazaki's Avatar
    Jan 06 2011
    New York
    3 fault codes
    Just wondered whether anyone has seen these 3 fault codes together?
    3 Faults Found:
    012600 - Intake Manifold Runner Control
    P3138 - 008 - Regulation Deviation - MIL ON
    Freeze Frame:
    Fault Status: 11101000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 148840 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2263 /min
    Load: 59.6 %
    Speed: 49.0 km/h
    Temperature: 96.0°C
    Temperature: 26.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.716 V
    008200 - Intake Manifold Flap; Bank 1
    P2008 - 001 - Electrical Malfunction - MIL ON
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 148840 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2305 /min
    Load: 60.0 %
    Speed: 49.0 km/h
    Temperature: 96.0°C
    Temperature: 27.0°C
    Voltage: 13.716 V
    000665 - Boost Pressure Regulation
    P0299 - 002 - Control Range Not Reached - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 149367 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2677 /min
    Load: 89.0 %
    Speed: 99.0 km/h
    Temperature: 94.0°C
    Temperature: 27.0°C
    Voltage: 13.843 V
    Oct 24 2015
    Perth, WA
    They seem related. If the manifold runner flap isnt operating correctly due to electrical faults you'll get boost issues.
    http://wiki.ross-tech.com/wiki/index...4/P3138/012600
    My respray thread
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Common issue with the motor. Intake runner flaps get stuck open. A solvent clean will help a little (maybe).
    Otherwise you'll need to replace your intake manifold and runner flap motor.
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Jan 06 2011
    New York
    Thank you very much... both
    My delay in responding was in trying to research more the advice against the codes.
    Can't say I've had much luck following extensive searches.
    The specific reasons for the codes seem different than in every other posted instance I can find.
    Not sure whether just to start changing simple/cheap stuff... or remove and inspect... or other external testing?
    Guess I'll get my head under the hood and see what I can find...
    Appreciated... and will let you know how it goes.
    Feb 15 2016
    Cambridge,Ontario
    I bet this is another side effect of DFI , coked up intake runners jamming the flaps.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jan 06 2011
    New York
    Just for a start, I decided idea to take off the motorized intake flap and clean. It wasn't that dirty, and what cold there was came off easily with brake cleaner. I also sprayed the connector with contact fluid and refitted.
    I did notice the rest position for the flap was with approx 1/8" open. Would be great if someone could confirm that?
    Thanks,
    Jan 06 2011
    New York
    200 miles and no CEL.
    Previously it came on after minimal miles with multiple codes, I had cleared the CEL's half a dozen times, to check consistency.
    Anyway, not quite counting my chickens yet, but the cleaning does seem to have made it think harder/longer!
    I would still like to know if the rest position for the flap should be ~1/8" open?
    Oct 24 2015
    Perth, WA
    Use VCDS to re-adapt the manifold flap motor and potentiometer (V157)
    My respray thread
    Jan 06 2011
    New York
    Yes, did that already, apologies for not clarifying.
    And all is still well!
    Thanks,
    Jan 06 2011
    New York
    Well.... lasted nearly a week without a code (CEL)!
    And the new codes are slightly different.... now getting this EVAP system, Very Small Leak Detected - Intermittent code.
    Anyone any ideas when this code is combined with Boost pressure regulation code?
    Doesn't seem to be pointing to the Intake flap valve anymore, since I cleaned it, but I don't know enough to really tell!
    Thanks, codes below:
    2 Faults Found:
    001110 - EVAP System
    P0456 - 001 - Very Small Leak Detected - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 150819 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1676 /min
    Load: 23.1 %
    Speed: 36.0 km/h
    Temperature: 60.0°C
    Temperature: 7.0°C
    Absolute Pres.: 1020.0 mbar
    Voltage: 14.351 V
    P0299 - 002 - Control Range Not Reached - MIL ON
    Freeze Frame:
    Fault Status: 11100010
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 150923 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2544 /min
    Load: 83.1 %
    Speed: 115.0 km/h
    Temperature: 95.0°C
    Temperature: 23.0°C
    Voltage: 13.970 V
    Readiness: 0000 0000
