Results 1 to 12 of 12
    Jul 23 2015
    Montreal canada
    ''waterfall'' sound in my dah
    Like the title said sometime usualy when I start my car or in the couple first minutes of driving I hear a sound like water from my dash .It doesn't do it every time .
    Someone has had the same problem?
    May 17 2012
    Houston, TX
    Yes, many of us have this. There is another thread where someone explains what this is. I forget so won't guess here, but I do know it's not a problem.
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    I think it's a bubble in the cooling system. I remember reading that it will not occur again if coolant tank is bled properly
    Nov 18 2014
    Jersey
    I have that too. No clue what it is. no fucks given.
    2018 Jeep GC Trackhawk
    2022 Audi SQ7
    2017 R8 TT. 1370whp.
    2007 Porsche 911 Turbo...Bolt On's
    May 06 2004
    W124s
    PA
    does your coolant level ever drop? coolant still look clean?
    Keep right pass left, it's the law!!
    Mar 26 2010
    US
    Coolant flowing through the heater core, with air pockets or turbulence.
    2019 RS5 Sportback
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Quote Originally Posted by wwhan View Post
    This, Gm's are really common to this. You just need to get the dealer or someone to bleed the cooling system out correctly. If you have a buddy with a vacuum lift it will do it and no more noise. I have the noise and it happens when I take off from a stop after it has been sitting for like 30 sec or so.
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    I have had this noise for 100,000 miles. Some people say its an issue, most say its not. Everyone who has the noise has no issues from it.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Sep 17 2015
    Vancouver, BC
    Very thankful that I found this thread as I always wondered if it was merely a bubble in the system.. Thanks!
    May 17 2012
    Houston, TX
    My coolant has never been too low. Not worried.
    Active Member One Ring Sergeant Kelly's Avatar
    Oct 09 2014
    '10 S4, '09 Suzuki XL7
    Chicago
    I get this occasionally if I'm sitting with the music off after some light driving. Does it sounds kind of like a bubbly, gurgly noise to you guys too? I imagine it's just bubbles in the coolant line, but it does give me little mini-heart attacks since I'm in a 2010 with the old water pump.
    Current Mods: APR Stage 2 ECU + Pully, ECS Kohlefaser Luft-Technik Intake, Misaligned Replacement Headlight
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    The old waterpump design has nothing to do with the air bubble noise in the heater core.
