    Apr 15 2014
    Ottawa/Gatineau Canada
    How the hell do I remove my Brake fluid Resivoir "strainer"
    the filter / strainer under the cap.
    On my other Audi's a quick twist and pull up would work. I can not seem to get this one out.
    Can anyone help me out here?
    I am getting brake fluid warnings when turning right, they turn off when I turn left.
    I want to inspect the level sensor "float" mechanism inside, however, I must remove the filter / strainer to do so.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    it clips in...you'll have to stick a pocket screwdriver in and pry a little and pull.
    once its out clean it REAL GOOD with brake cleaner as the net gunks up.
    Apr 15 2014
    Pry between the 2 sections (filter and housing) ?
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A4%20B6/B8
    Arizona
    Quote Originally Posted by Luxus Panzer View Post
    Yup. It's hard to get out but possible. I used a pair of needle nose pliers and pulled it out. Didn't come out smoothly though.
    Nov 02 2007
    SF Bay Area, CA
    yeah...mine deformed but while i had it out i bent it slowly to the correct shape. try not to bend it too much as the plastic could split if bent too much.
