Results 1 to 18 of 18
    Mar 29 2012
    SF
    Stereo volume raises and lowers erratically
    I have an '07 A4 Quattro with Bose speakers and the volume goes up and down randomly for no reason. It's really annoying. It did this with the stock RNSE unit as well as with my new Pioneer 7100NEX. The stereo guys have no idea what it's about. Any thoughts?
    Oct 24 2015
    Perth, WA
    Is there some kind of speed related volume effects? Ie, gets louder as you go faster?
    My respray thread
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    i believe its a feature called (GALA/DSP)
    This is something to do with BOSE. If you have BOSE it uses something called AudioPilot that changes the volume and tone depending on speed or interior noise. If you don't have Bose the speed dependent volume is called GALA, but shown on the RNS-E as DSP. GALA/DSP is disabled by setting it to zero from the menu.
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by nizmosx View Post
    This ^.
    To the OP: Just had to comment to say props on using the word "erratically". Lol
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Mar 29 2012
    SF
    That's because IT IS erratic lol. Constant up and down for no damn reason. And how would I disable it in "the menu"? It has an aftermarket stereo now.
    Established Member Two Rings Demonface's Avatar
    Jan 23 2015
    Jersey/ Miami
    On my car I believe it's called VSC , it's basically when the faster you speed the louder it gets and the when you slow down its gets lower . I turned that feature off a few weeks back. On your aftermarket radio it should be in the settings . If you look in the manual it might be noted .
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    FYI, even non Bose Symphony II+ have this feature. Enabled by default, but you can quickly disable it on the headunit (via menu).
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Mar 29 2012
    SF
    Right so wouldn't it become disabled or go away all together once you take out the headunit and put in a Pioneer one?
    Feb 13 2004
    Lakewood, CA
    Not if the pioneer one has that feature as well. Look at your manual and see if it has that feature and if it does, disable it. If it does not have that feature and the volume is still erratic, then you definitely have a different issue going on. Probably wiring or faulty head unit.
    Mar 29 2012
    SF
    There's no feature for that. Damn this is becoming a huge pain in the ass for me.
    Veteran Member Three Rings baldy's Avatar
    May 11 2010
    Aprilia RSV4RF, Yamaha R1, '15 A3 TDI
    BC
    Quote Originally Posted by inked_up415 View Post
    There was a TSB to disable Audiopilot..... I copied the text, so here you go:
    Condition:
    Customer perceived condition of radio volume changing by itself may be caused by the noise compensation function Audiopilot”, which is part of the BOSE amplifier. Some customers may find this function to be too aggressive and for some individuals a
    noticeable volume fluctuation can be heard.
    Note:
    Audiopilot can not be selected in the radio menu. The selectable radio function “SVC“ is a vehicle speed controlled volume adjustment and operates independently from the Audiopilot.
    Note:
    This condition is not related to in-car microphone. Do not muffle or disconnect microphone.
    Overview
    There are two different Service Procedures incorporated into this Technical Bulletin.
     Audiopilot Deactivation
     Enabling Speed Volume Control (SVC), if necessary.
    The BOSE amplifier Audiopilot function can not be disabled in the radio menu. The wiring harness electrical connector must be
    modified.
    – If necessary, remove ignition key from ignition lock cylinder.
    – Remove necessary trim. See appropriate Repair Manual, Body Interior, Repair Group 70.
    – Disconnect amplifier electrical connector.
    – Remove tie strap and electrical connector cover
    – Remove insulating tape on harness to expose additional wiring.
    – Locate white wire in cavity 6 on harness
    – Cut white wire Make sure there is enough wire on both sides of cut to install a butt connector.
    – Strip insulation on both wire ends 6-7 mm (approx. 1//4 inch).
    – Install blue butt connector onto harness side of white wire.
    - Crimp butt connector using appropriate crimping tool
    – Push locking tabs outward and slide SMALLER inner hardshell out of outer hardshell
    - Release inner hardshell wire lock by rotating outward.
    Note: Release lock on Pin 24/25 side of connector.
    – Insert terminal of repair wire Part No. 000 979 025A into cavity 24 of amplifier connector.
    – Assemble inner and outer hardshells.
    – Route repair wire to open side of butt connector -black arrow- and cut repair wire to length.
    – Insert connector side of white wire into open side of butt connector
    – Re-tape exposed wiring and reassembly amplifier electrical connector.
    – Connect amplifier electrical connector.
    C7 A6 TDI - TurboSystems 2872..Wagner IC..CGQB fuel system+MAF..RS6 intake..Eurocode sways+inserts..Eibach springs..H&R 15mm spacers..JXB support..Powerflex diff inserts..Waxedshine PPS...OE hitch..HBA retrofit
    Oct 24 2015
    Perth, WA
    He has aftermarket Head Unit.
    OP, may be put the old HU in and disable, then reinstall your new HU.
    My respray thread
    Senior Member Three Rings ImAudiHeree's Avatar
    Jun 30 2014
    Mercedes Metris
    Sacramento, CA
    Jun 30 2014
    Mercedes Metris
    Sacramento, CA
    Idk if it applies to b7s as far as pin out goes
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    I have this feature on my 25 year-old Alpine 7525 deck which I still owned to this day. Didn't know they still use it.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    May 11 2010
    BC
    The wiring mod in the TSB still applies since the Bose amp is what has the circuitry built in, and th mic connects to it. Doesn't matter what deck is installed.
    Mar 29 2012
    SF
    Thankyou for getting me on the right track. Most of all that instructional info flew right over my head but I will show it to my audio installer.
    If I remove/bypass the BOSE amp then problem solved?
    May 11 2010
    BC
    Coles notes to bypass audio pilot:
    Disconnect plug from Bose amp
    Insert the repair wire Part No. 000 979 025A into cavity 24 of amp plug
    Connect it to white wire that's in pin 6
    Done.
    Running the speakers off the deck vs the Bose amp will disable the factory sub and dash speaker. So I wouldn't do it.
