Results 1 to 8 of 8
Thread: Stage 3 tune
    Dec 06 2009
    1998 2.8 A4, 2002 S4 6spd
    Coastal, Ma
    Stage 3 tune
    have 2002 S4, just completed upgrades on car. SRM K04 RS4 hybrid turbos, SRM intercoolers, SRM billet diverter valves, Miltek downpipes to MTM catback exhaust, 034 85mm hitachi MAF housing to 034 carbon fiber cold air intake, 034 ICM delete kit with Audi R 8 coils, Bosch 040 fuel pump, Bosch 60lb/630cc injectors, 034 3.5-5.0 bar adjustable for, 034 motor,transmission and rear dif mounts, new radiator and all seals,belts and hoses replaced in last 6k miles. Drive train and suspension done in the same fashion. My question.? Who do I use for stage 3 tune ASP, EPL or Daz at Vag.
    Established Member Two Rings Gotwake424's Avatar
    Dec 14 2014
    DavidhogAJ
    Philippines
    Preference..
    Everyone will come on here and tell you who they used and who is the flavor of the month, year etc.
    I went with Daz and had no complaints, you will need a vag-com cable and a wideband however.
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Yah its going to be up to you and who is the most accessible for you. Are you able to log and flash yourself or do you just want someone to tune it and be done?
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    PM sent
    2001 S4 Sil Sedan ASP Stage 3-Current
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2002 S4 Pearl White Avant Stock--SOLD
    2000 S4 Nogaro Sedan EPL Stage III--SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III--SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s--SOLD
    2001.5 Nogaro Sedan AWE Stage III--SOLD
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast--SOLD
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by revsmojito View Post
    I thought the MTM exhaust used a single 70mm pipe, you may want something a little larger with the K04 hybrids.
    Dec 06 2009
    Coastal, Ma
    Thanks for the solid info. Will get in touch with Jared and let him know of your recommendation
    Dec 06 2009
    Coastal, Ma
    Considering going with a fast intentions stage 2 catback. Will decide when I figure out how much I've spent to get here. May have to wait abit.
    Feb 14 2005
    No problem at all.
    Have a friend selling a 3" single Borla exhaust. If you're interested shoot me a PM and we can go from there.
