Page 60 of 115 FirstFirst ... 1050585960616270110 ... LastLast
Results 2,361 to 2,400 of 4571
  1. #2361
    Veteran Member Four Rings AUDacIouS4's Avatar
    Mar 11 2016
    981 Cayman GTS/ 2018 Ford F150 FX4 2.7
    Orange County CA
    Quote Originally Posted by B8_Dude97 View Post
    Who says you can't datalog and crunch numbers while driving
    When you need to really be "because racecar" mode
    Word!!^^^^ thats what I've always done.
    You want 4th gear in the ZF8, not 3rd. 5th gear is ideal as that's the most load the engine sees.
    If your willing to go 85mph on the streets in 3rd, why not go 98-100in 4th? Go out on the highway in the wee hours of the morning or find a good backroad, you'll be fine.
    Be careful with logging values on the Allroad, there are a lot of parameters that are "decoys". I'll send you a screenshot of my saved parameters from GIAC so you can be certain you get real data.
  2. #2362
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    @ earhythmic
    Does the car pull hard af? What are your initial impressions?
    Ohhh yes! You get that torquey “sucked back into the seat” feeling in any gear at any rpm. I’m going to try to make it to Sac Raceway Wednesday to get some 1/4 mile times. Come oooon 12.2!
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
  3. #2363
    Sep 17 2006
    Quote Originally Posted by AUDacIouS4 View Post
    Perfect. Yes please.
    past: B6 S4, B5 A4
  4. #2364
    Veteran Member Four Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI 8V A3 - B8.5 Q5 - MKVI GTI
    Hawaii and Utah
    Why not post the parameters here?
    CPMA / CTS K04-0064 / IE custom tune / Wagner FMIC / Custom ZF8 TCU tune
  5. #2365
    Veteran Member Three Rings B8_Dude97's Avatar
    Sep 05 2016
    Antioch, California
    Quote Originally Posted by earhythmic View Post
    Ohhh yes! You get that torquey “sucked back into the seat” feeling in any gear at any rpm. I’m going to try to make it to Sac Raceway Wednesday to get some 1/4 mile times. Come oooon 12.0!
    Fixed that for you. Better start a diet on yourself or get a skinny man to drive
  6. #2366
    Sep 17 2006
    Lol I’m already pretty skinny. Maybe I should load the hatch with some balloons.
    past: B6 S4, B5 A4
  7. #2367
    Sep 05 2016
    Antioch, California
    Oh definitely. Have you weighed your wagon?
  8. #2368
    Sep 17 2006
    Negative. But I ran a 13.2 with my stage 2 so with the K04 I’d say things are promising.
    past: B6 S4, B5 A4
  9. #2369
    Aug 17 2015
    California
    Anyone know the stock cracking pressure of the wastegate on a K04 setup?
    You can log it by unplugging the N75 electrical connection, then your car will only boost up to the wastegate cracking pressure. Somewhere around 6-12 psi.
  10. #2370
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    So everything is up and running strong. I’ve been requested by a few to do some data logging and I’m willing. My question is what are the best practices and relevant information in doing so. I’ve read the APR guide and also the write up in the S4 forum, but will 3rd gear suffice or must it be 4th gear? How does one prevent from gear kickdown if starting at 1500 rpm, or am I starting at 3000 rpm (the two guides I’ve read are contradictory)? And are several runs needed to average out the results or would one pull suffice?
    The pedal has a kickdown switch. If you press the pedal all the way in manual mode without the last like 1% of travel (you can feel it), it will not downshift
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  11. #2371
    Sep 05 2016
    Antioch, California
    Very ill be tuned I. For results and maybe another video by you of your run? Your edits are pretty damn nice
  12. #2372
    Mar 11 2016
    Orange County CA
    Quote Originally Posted by Perry01 View Post
    I will when I get home. Patience young Paduan
  13. #2373
    Jan 22 2016
    Hawaii and Utah
    Thanks Master Yoda :-)
  14. #2374
    Mar 11 2016
    Orange County CA
    Here you go gentlemen:
    Now go shoot some fireballs !!
  15. #2375
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Wrong car!. Mqb chassis!!. Now this is more like it!.. tho as you say to heavy and long for competitive track use!..lol
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
  16. #2376
    Mar 11 2016
    Orange County CA
    Quote Originally Posted by hyperunion View Post
    They pulled those A4's out for 2016
  17. #2377
    Established Member Two Rings b8_Jeff's Avatar
    Jul 24 2013
    2018 A3
    Alamogordo, New Mexico
    So I got back from deployment a month and a half ago and had my APR k04 installed before I got back. 5 days later I lost all compression in cylinder 1. After a month and a half, ill finally get the car back today. Lots of work done by IE & Etektuning in las vegas. ill follow up with a build list and everything as soon as I can. with the now built engine, I will most likely ditch the APR tune and get a custom one. That being said, the custom tuner has a dyno and I will also post those numbers as well.
    CURRENT 2013 Audi S6---Phantom Black---Black Optics---Avant Garde M520 Wheels---Michelin Pilot Spot All Season 4
  18. #2378
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    Yep... they're fun to drive on twisty mountain roads, but they're not track cars. Too heavy.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
  19. #2379
    Jan 15 2014
    Boston, MA
    So another Allroad with a CTS K04 just ran a 12.3 like I did. I think this is more solid proof that there’s something about the CTS
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  20. #2380
    Jan 15 2014
    Boston, MA
    Revision to above statement. He ran a 12.5 and 12.6. I’m like live tweeting this haha
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  21. #2381
    Sep 17 2006
    Hi
    past: B6 S4, B5 A4
  22. #2382
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    ^ Woot!
  23. #2383
    Aug 17 2015
    California
    Very nice work.
    How can I get a 1.8s 60 foot time?!
  24. #2384
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Hi
    sweet! E85?
  25. #2385
    Sep 17 2006
    sweet! E85?
    Yessir! It was from my least favorite spot though, their ethanol content is typically extremely low. I’ll be sure to have the good stuff for Audi Night, I need to hit that 12.3 to shame Dru.
    past: B6 S4, B5 A4
  26. #2386
    Aug 31 2011
    Lathrop
    Haha Dru's at 12.1!
    We got the K04-R on our car and it's looking really good. We may have it at Audinight as well
  27. #2387
    Sep 17 2006
    Haha Dru's at 12.1!
    Haha dammit! Looks like I need to shave off .4s then.
    Looking forward to seeing it run. Can’t wait!
    past: B6 S4, B5 A4
  28. #2388
    Jan 15 2014
    Boston, MA
    Who is dru. And with what turbo did said person run a 12.1.
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  29. #2389
    Aug 31 2011
    Lathrop
    Quote Originally Posted by AllroadCorbin View Post
    Employee at JHM, TD05H-R
  30. #2390
    Jan 15 2014
    Boston, MA
    Nice
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  31. #2391
    May 20 2017
    Orange County/California/SoCal
    APR tune?
    2014 A4 Tiptronic, IE Intercooler, UnitedMotorsport, JHM HFC, STOCK Intake, AWE Tuning A4 Touring Edition Exhaust - Quad Tip. Sportline 7S Gunmetal 19x9.5 ET40, EuroCode Alu Kreuz, 034 Rear Sway Bar/End Links.
  32. #2392
    Aug 31 2011
    Lathrop
    Quote Originally Posted by bhuynh1804 View Post
    APR tune?
    ya
  33. #2393
    Sep 17 2006
    past: B6 S4, B5 A4
  34. #2394
    Sep 03 2012
    Lehigh Valley, PA
    Manual or automatic b8?? Flex fuel car?
  35. #2395
    Aug 31 2011
    Lathrop
    6mt b7
    On side note, the K04-R is installed on our shop B8 (6mt) and running great with APR K04 3.1 Software. Boost spikes and meets requested at 2400RPM and holds till redline, MAF GS hits 279, and N75 hits a low of 69% and at only 78% at redline.
  36. #2396
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    6mt b7
    Any movement on a tune available for that turbo (TD0-5HR) on a B8 6MT car?
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
  37. #2397
    Aug 31 2011
    Lathrop
    Quote Originally Posted by poweredbyaudi7 View Post
    Bringing the TD05H-R to the B8 platform is still something we are looking into, and want to do
  38. #2398
    Mar 11 2016
    Orange County CA
    Mustang dyno. 92* in the shop
    291whp/336wtq.
    GIAC stage 1+ E85 race file.
    44% Ethanol content
    Water/meth setup (100 ML/Hr throttle body nozzle and 175 ml/hr post IC nozzle)
    034 HFC/MILTEK DP/Magnaflow catback
    APR FMIC
    ECS intake and turbo muffler delete
    And here's the kicker...this was the same exact dyno that the UM tuned k04-R was on two months ago with my graph(In red) overlayed on his 91 pump run courtesy of the tuner.
    K03+E85+meth = nice kick in the nutz
  39. #2399
    Sep 03 2012
    Lehigh Valley, PA
    291whp/336wtq.
    44% Ethanol content
    APR FMIC
    Strong numbers indeed!.. ones I hope too match!!
    Definitely some life left on the stock ihi's... We really need to see the " r turbo" to surpass these numbers!.. will we see it..???
  40. #2400
    Mar 11 2016
    Orange County CA
    I forgot to mention that I'm only running 19 psi peak boost tapering to 13.5. Requested is 22.5 tapering to 16.5......damn ginormous FMIC!!
    A custom tuned k03 E85 on meth would push another 20whp/30wtq
