Page 51 of 115 FirstFirst ... 41495051525361101 ... LastLast
Results 2,001 to 2,040 of 4571
  1. #2001
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    Quote Originally Posted by bhuynh1804 View Post
    I don't think UM specifically comments on the hardware itself, at least not yet up until now. I'm the guy running k04-R with UM btw incase you wonder.
    I was just throwing my thoughts out there, but ither than those two things this jhm k04 r is supposed to be just like a real k04. So...
  2. #2002
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    So it's possible since this is all heresay, just like an IE intake manifold, you get poor results and loss of power if the tuner hasn't figured out how to tune for it, yet IE does know how to tune for it gets an increase in power.
  3. #2003
    Feb 08 2017
    Quebec
    Quote Originally Posted by Alex1188 View Post
    Actually, every modifications they bring to a turbo is.. And I'll quote them "to be up to oem standard or better ". Even if it's a k04, it has been modified in ways that either are meant to outperform or act differently.
    The example they've given is how.. A b7 with a k04 and a b7 with a k07-r beat the b7 k04 by pulling ahead due to a beefier top end.
    The clipped wing is "supposed" to give a better mid and top end, and not die put in high rpm ranges like a normal k04 would.
    This hasn't been proven so far. Reports do show it takes longer to spool Vs a regular k04. Let's see if it can hold boost till redline, if it offers a Better torque curve, a flatter one.
    Let's see if someone can tweak and make use of those supposedly improvements.
    Not everyone wants a full spool at 4K
  4. #2004
    Veteran Member Four Rings AUDacIouS4's Avatar
    Mar 11 2016
    981 Cayman GTS/ 2018 Ford F150 FX4 2.7
    Orange County CA
    UM has tuned hundreds of BW k04 setups. It's simple: they requested boost targets like a k04 and the JHM K04-R wasn't able to meet those targets via the logs. The conclusion is that the k04-R doesn't flow as many lbs/min as a standard BW k04. It's like running a k03 turbo with a k04 tune and expecting the k03 to meet the boost targets... it can't. With the right tuning, the k04-R will shine in its own way. It just might end up somewhere in between a k03 and a BW k04??
  5. #2005
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Kinda glad I didnt pull the trigger on that group buy lol
  6. #2006
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Quote Originally Posted by AUDacIouS4 View Post
    There isn't a conclusion yet. The K04-R has the same size wheels as an OEM S3 K04 so it is not like running a k03 with k04 software. There is an issue somewhere and when it is found it will be fixed.
  7. #2007
    Mar 10 2013
    Quote Originally Posted by Jake@JHM View Post
    Jake curious as my question wasn't answered last time I asked you.... Does anyone at JHM physically check these K04R turbos before they are sent out? Like physically check wastegates are set right? Or anything like that?
  8. #2008
    Aug 31 2011
    Lathrop
    Yes, final assembly is done here and wastegates are set. I believe I did answer your question as I can recall answering it. Maybe I got side tracked and forgot to hit post?
  9. #2009
    Mar 10 2013
    IDK, I could be wrong, you may have, I don't recall seeing it, but either way its been answered now. I appreciate it sir! Was just curious if maybe this was done by the manufacturer and had a possible mis adjusted wastegate. Seems to me with the logs that were posted it would be a good suspect for falling boost pressure. That or he has a horrible boost leak.
  10. #2010
    Aug 31 2011
    Lathrop
    Well unfortunately we are not all robots yet so it is possible a wastegate could have been set improperly. It hasn't happened yet and we set many wastegates between K04-Rs, RS6-Rs amd TD05H-Rs but it's possible.
  11. #2011
    Veteran Member Three Rings Brandon K.'s Avatar
    Apr 17 2016
    2017 Golf R, 2018 Q7 3.0T, 1991 Saab 900T
    Vancouver WA
    Jake
    What base boost should the K04-R wastegate be set to?
  12. #2012
    Mar 10 2013
    What the pressure/crack measurement your team has been setting these to out of curiosity? Maybe we could rule this out, have him log the car with the n75 valve unplugged which would divert all pressure to the wastegate and run base pressure. Log it and see what the max pressure he can run is. Would give us a good idea at least I would suspect.
  13. #2013
    Established Member Two Rings B1GW3AV3R's Avatar
    May 04 2017
    2002 Honda s2000 2001 Audi s4
    PA
    Can anyone tell me if this is a normal sound, this is an HPA K04 right when I hit around 5k rpm it makes a whining sound , 2nd gear roll at 20mph. Private road..
    https://youtu.be/3dPD_FUjUMM
  14. #2014
    Mar 10 2013
    Quote Originally Posted by B1GW3AV3R View Post
    That's the compressor riding the surge line, it's normal, that's aggressive tuning.
  15. #2015
    May 04 2017
    PA
    I wish I knew more about cars... Every time I hear a noise I shit myself. Lol
    Sent from my Pixel using Audizine mobile app
  16. #2016
    Mar 10 2013
    My F23 will do it as well when I have the boost turned up. Aggressive tuning makes for a fun filled car, you get the whole experience... Sounds and power.
  17. #2017
    Feb 26 2008
    washington
    B8 Ko4 owners follow up thread
    After I installed my HPA k04, I had a similar noise under higher rpm and load. I had an intercooler clamp that was bottomed out and leaking.
    I would recommend everyone to pressure test after any kind of turbo, intercooler, piping install.
    It could be normal but you never know and might as well make sure your setup is 100% before pushing it and blaming the tune.
  18. #2018
    Veteran Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    Quote Originally Posted by A4x View Post
    Calling on @A4 Centaur and @ Poodini for some logs!
    Yo! Brief update. The k04-R is up and running since late Monday. I ran into a minor setback which should be corrected tomorrow.
    Also, I'm currently running it with my current 3.0l TDi intercooler. Thus far it's held up fine. My next install will be to hook this new FMIC courtesy of ECS Tuning! Once that's on, I'll feel a little better about throwing some performance numbers up. Til then, enjoy for those who bought a
    Stay tuned...
  19. #2019
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    Well this is materializing in interesting ways, I'm looking forward to legit feedback and logs to support.
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
  20. #2020
    Veteran Member Three Rings Fastbke170's Avatar
    May 01 2015
    2003 Silver GSXR1000, Mazda 3S 2006
    Northport
    Wow that noise would scare the shit out of me. Sounds like turbine hitting housing.
    Sent from my SM-G950U using Tapatalk
    2012 A4 Moonlight Blue Metallic : Premium +: RS6 18" GUNMETAL WHEELS: AEM PRO DRY INTAKE: FRANKENTURBO F23L : TopGear UK HFC : TopGear UK 3"Stainless Steel Turbo Back Full Dual Exhaust: TopGear UK Eurodyne Custom Tune:Eurocode FMIC :3 Spoke S4 Black Steering Wheel w/DSG Paddle shifter : S-Tronic Shifter Knob w/Black Boot : LED White Interior: LED Red Footwell Conversion : Hoen White XEON Match Fog Bulbs :R8 Coil Packs: Puddle Projection Lamps with Audi Rings
  21. #2021
    May 04 2017
    PA
    Quote Originally Posted by audisean1 View Post
    I'm running APRs FMIC, I'm thinking of getting better aftermarket hoses and a new turbo inlet. I'm not sure how to do a pressure test
  22. #2022
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    You could make one of these, or buy this one to be lazy like me
    http://turboboostleaktesters.com/vw-...o-intake-pipe/
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
  23. #2023
    Aug 17 2015
    California
    I need to do a pressure test as well. It seems easy enough, I'm just not sure what to do with the PCV. I know you have to unhook and plug something so you don't blow the pressure back into the PCV.
    Is it just the one line that runs from the turbo inlet to the intake manifold? Disconnect that from the turbo and plug it?
  24. #2024
    Feb 26 2008
    washington
    Yes that is it. The connection at the back of the intake manifold.
    Then listen and/or use soapy water at all connections and components.
  25. #2025
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    Just logged 2nd gear. Spikes at just over 24 psi and at red line was at 19.2 psi.
    This is calculated from mbar and then atmospheric pressure subtracted
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  26. #2026
    Aug 17 2015
    California
    Quote Originally Posted by AllroadCorbin View Post
    MAF g/s?
  27. #2027
    Jan 15 2014
    Boston, MA
    MAG g/s?
    I'll do that in a few
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  28. #2028
    Jan 15 2014
    Boston, MA
    Shows 902. So nothing crazy. Clearly there's a lot of elements at play to make power
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  29. #2029
    Aug 17 2015
    California
    902 what units? That doesnt make sense unless it is kg/h which 902 kg/h = 250 g/s. But if youre logging the same parameter we are at the MAF, the readout is in g/s.
    What field was it?
    Are you using VCDS or torque?
  30. #2030
    Jan 15 2014
    Boston, MA
    902 what units? That soesnt make sense unless it is kg/h which 902 kg/h = 250 g/s. But if youre logging the same parameter we are at the MAF, the readout is in g/s.
    What field was it?
    APR mobile. 902 kg/h
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  31. #2031
    Aug 17 2015
    California
    Thanks for logging! Any chance to get your N75 duty cycle? Maybe a 3rd gear pull with a graph? (If you're 8 speed auto, otherwise 2nd might be ok if manual).
    So we have a CTS kit logged with APR mobile app, spiking 24 psi and tapering to 19 psi with 250 g/s airflow.
    My JHM turbo logged with VCDS spiked at 22 psi and tapered to 16 psi with MAF 260 g/s. My N75 duty was pegged at 100% tho.
  32. #2032
    Jan 15 2014
    Boston, MA
    I'm running a full tank of E85 right now. I usually notice higher peak boost on 93. I think the timing advance takes care of some of the extra load usually done by boost. 26 psi vs 24.5 on E85. I would assume more boost needs more air so I'll try on that's too. We are also measuring using difference devices so who knows
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  33. #2033
    Aug 17 2015
    California
    Yea VCDS vs APR mobile vs Torque might give slightly different readings?
    I also saw a parameter like "airflow through throttle body" and that was reading out in kg/h but was significantly less than my MAF signal in g/s. I'm confused
    I didn't know there was any sensor in the throttle body for this.
    I wonder where your kg/h signal is coming from and if we can compare it to my g/s signal.
  34. #2034
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    If you guys are trying to build a database you need to settle on a logging standard so that the data is meaningful. Maybe a Google Sheets document with the Fields labeled, I would suggest something like:
    Platform: Trans: Fuel: Tune: Turbo: MAF g/s: N75 Duty Cycle: Gear # Peak Boost Requested: Peak Boost Actual: Altitude:
    B8 6MT 93 XXX K04 hybrid 300/g/s XX% 3rd 20psi 19psi +100ft
    Otherwise this thread is going to be a mess of meaningless singular data points.
    Field Rationale:
    • Platform: prefacelift or not, subtle changes, Intake manifold, extra injector, different lpfp for E85...
    • Trans: This will affect shift points, gearing etc
    • Fuel: 91/93/100/E85, all make huge differences to overall tune/power
    • Tune: duh
    • Turbo: try to create a consensus around how each custom turbo performs
    • MAF g/s: Coupled with altitude this should provide a mechanism to estimate "power" in a properly performing vehicle. Indicates "power"
    • N75 Duty Cycle: Quantify how "well" the turbo is making boost, is it ragged edge barely meeting requested at redline for example?
    • Gear: Makes a difference for load based calculations
    • Peak Requested:
    • Peak Actual: is the turbo actually performing? are we outside compressor efficiency map?
    • Altitude: This plays into MAF reading and air density which has a major impact on overall power.
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
  35. #2035
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    thank you @IHave2Turbos !! i would be enthusiastic to contribute to a google doc. particularly with my HPA k04 + IM kit on Meth.
    otherwise garbage in = garbage out, and frankly i feel this thread has turned into garbage.
  36. #2036
    Jan 15 2014
    Boston, MA
    Ok if somebody wants to set that up and we can PM them our emails.
    We can even make excel tabs for dyno figures for various set ups/dyno types
    I think we already have a 1/4 mile sheet no?
    Regardless organized data would be a welcome change on this forum. I can't make one right now but I could potentially this weekend
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  37. #2037
    Jan 15 2014
    Boston, MA
    FYI I calculated my boost incorrectly.
    On E85 it read out 2746 mbar. I'm at sea level which is 1013 mbar.
    So 1.733 bar X 14.7 = 25.47 psi peak
    The redline calculation redone shows 19.6 psi
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  38. #2038
    Jan 15 2014
    Boston, MA
    Not to drag this on but I don't see the point of comparing g/s airflow. Since actual measured boost is the direct result, who cares what the other number is. There's so many variables in that and possible inefficiencies. Measuring the actual boost that results at the manifold is what y'all should be comparing. That's the real flow haha
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  39. #2039
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    The first step is deciding which application to measure with...
    Unless you want to create three tabs of spreadsheets, one or each respective app (VCDS / Torque / APR, etc).
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
  40. #2040
    Aug 17 2015
    The MAF g/s is the maximum possible amount of air flowing into the closed system (assuming no leaks allowing in un-metered air) and it is directly related to the theoretical maximum amount of power the engine can make/is making.
    So in theory, Company 1 K04 reading 300 g/s is likely making more power than Company 2 K04 reading 280 g/s, the differences in timing, n75 duty, fueling, requested boost vs actual boost would be factors telling us "why" they are making more power.
    Disclaimer: IANAT (i am not a tuner...) so please school me if this is wrong
    C7.5 S6
    B8 A4
