Results 1 to 11 of 11
    Established Member Two Rings Swat413's Avatar
    Nov 30 2015
    2005 Audi A4 Ultrasport
    Boston, MA
    Mongoose Cable help
    I received my Mongoose cable, Vehicle Interface Cable, and I am trying to activate it. It is failing when it tries to talk to the server. I am running Windows 10, firewall is off, using IE and have tried Edge, all drivers are installed and installation goes fine until final activation. Has anyone else had this problem and know the solution? Thanks
    Current: 2018 RS3 // Ara
    Current: 2005 A4 USP // Brilliant Red
    Senior Member Two Rings jmaddr's Avatar
    Jun 19 2013
    United States
    What software are you trying to use it with? It might help to contact them. Work EPL, their software needs activation before use. To do that, you send them your serial number.
    Nov 30 2015
    Boston, MA
    Yes EPL. I shot an email to Drew Technologies a little while ago with this, waiting to hear back.
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    I went to the website on the instructions that came with the box. That seems to do the trick.
    I do wish EPL gave better instructions on the whole process (website?)
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Nov 30 2015
    Boston, MA
    Mongoose Cable help
    Quote Originally Posted by cjw View Post
    Ya I did follow the instructions, it fails at the last step as it says it cannot contact the server from Drew Tech
    The EPL website is "Coming soon"
    Nov 30 2015
    Boston, MA
    Nov 30 2015
    Boston, MA
    Bump. Anyone have this problem?
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    I believe this is a Windows 10 issue. There was a thread similar to this not too long ago and the guy resolved the issue by switching to a tablet using Windows 8.1
    EDIT: Here is the thread: http://www.audizine.com/forum/showth...-install-issue
    2016 S6
    Nov 30 2015
    Boston, MA
    I will try it on a Windows 7 machine on a different network and see if that fixes it.
    Account Terminated Four Rings
    Mar 22 2016
    73 Jimmy 496 BBC
    I just did this with Tony at EPL. I have windows 10 and everything worked perfectly.... email Tony he will help you.
    Nov 30 2015
    Boston, MA
    Drew Technologies, whom you activate the cable first through, sent me a new link that worked. FYI to anyone trying this.
