Results 1 to 10 of 10
    Apr 08 2013
    Northern California
    Limp Mode Nightmare!! Please help
    Hi guys my car has been in the shop for over a week now. My mechanics are stumped and so am I.
    I replaced my old cat with an 034 hfc last week. I ended up taking it to my local shop because it sounded like an exhaust leak and low and behold the 034 supplied gasket from cat to dp had failed in one day! My mechanic replaced the gasket and everything looks fine. We went for a test ride and now I am only getting 5 psi which is weird because I had full boost with the exhaust leak. So I am somehow stuck in limp mode.
    The car is running fine.
    There are no codes.
    No boost leaks.
    Swapped ecu's.
    Swapped MAfs.
    Swapped n75.
    Any ideas/suggestions?
    2001 B5 a4 1.8t
    ~2001 a4 1.8tqm~ Giac-X chip, Apr exhaust, Koni Yellows/Eibach Springs, 17in Br05 BremmerKraft Rims, Pheonix Gold Amp, Alpine deck, 2 12in Boston G1 Subs.
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    Quote Originally Posted by BaronB5 View Post
    There are no codes.
    No boost leaks.
    Swapped ecu's.
    Swapped MAfs.
    Swapped n75.
    2001 B5 a4 1.8t
    How does a thick gasket fail in one day? I got mine installed a few months back along with a new cat back and down pipe. Only thing I recall was the burning smell from all the new parts being broken in.
    01 1.8T | B6 Sport Wheels | Forge diverter valve | A8/TT Front Brakes/SS lines | 034 HFC & Milltek Resonated CB | APR TIP & Intake |
    Apr 08 2013
    Northern California
    Quote Originally Posted by SN95Audi87 View Post
    It split straight down the middle. I'll post pictures tomorrow but that was pretty lame.
    Established Member Two Rings Blur2u's Avatar
    Oct 01 2004
    San Diego
    Did you try clearing/resetting the ECU? Also unplugged the battery for a while and that should reset everything, see if the car goes back into limp mode.
    Apr 08 2013
    Northern California
    Quote Originally Posted by Blur2u View Post
    I swapped in my old stock ecu and it still wouldnt go past 5 psi. No cel either
    Apr 08 2013
    Northern California
    Turned out the vacuum line from intake manifold to my boost gauge had a hole in it. Everything is fixed. Thanks for replies!
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    I was going to mention that as a possibility, but the one time it happened to me it also affected my vacuum readings. The warmer the car got, the better the readings, I guess mainly because the line would swell with the heat helping to seal the leak.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Apr 26 2010
    North Jersey
    I guess it wasn't lame after all.
    Apr 08 2013
    Northern California
    The lame I was referring to was the failure of the gasket after only one day. I'm calling them today to get my money back
    Apr 26 2010
    North Jersey
    Ok I understand now. Very weird to see something high quality do that though.
