Results 1 to 40 of 54
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: ECS Flush Fit Kits | Up To $50 Off!!- Limited Time Only
    The German TUV (Technical Inspection Association) has determined that in several European countries the clearance between fender and tire must be adequate to accommodate snow chains when safety requires.
    In North America, where no such law exists, RS4 owners have the option of restoring Audi's original intention of providing a focused race-bred machine by widening their car's stance, improving road-holding and performance aesthetics.
    Improve your stance appeal with the in-house fit/tested hubcentric ECS spacers and appropriate length wheel bolts.
    Need Some Space?
    Fits:
    Audi B7 RS4 2007-2008
    Jason
    Senior Member Two Rings SQ RS4's Avatar
    Feb 02 2015
    2008AudiRS4 2016AudiS6 2009NissanGTR 2016HondaPilot
    Clarksburg, MD
    Was going going to pony up the $ for some MTM 10mm spacers, but this is a pretty good deal.
    Anyone have any experience with these? Any issues using these with OEM wheels?
    Oct 02 2006
    Wadsworth,OH
    Our spacers are engineered to work specifically with OEM and OEM style wheels!
    Jason
    Junior Member Two Rings iduff's Avatar
    Sep 19 2015
    B7 RS4, MK7.5 Alltrack
    New Bedford, MA, USA
    I have these, 10mm for both OEM wheels for summer, and Kahn wheels for winter. No issues, work as expected.
    B7 RS4 Sedan, Phantom Black Pearl
    KW V3, JHM discs, Porterfield R4S pads
    MK7.5 Alltrack,Tornado Red
    New, stock
    Former Audis
    2007 B7 RS4, 2014 B8.5 allroad, 2000 B5 S4 Sedan, 1995.5 C4 S6 Avant, 1990 Type 89 Coupe Quattro, 1987 Type 44 Quattro S Sedan
    Feb 02 2015
    Clarksburg, MD
    Quote Originally Posted by iduff View Post
    Thanks for chiming in. Are you lowered, or on stock suspension?
    Sep 19 2015
    Quote Originally Posted by SQ RS4 View Post
    Not lowered, stock suspension.
    New, stock
    Former Audis
    Apr 20 2009
    Orange County, CA
    I've used ECS spacers for years (10mm and 12 mm) and they work exactly as advertised for much less than competing brands. Make sure to also use extended lugs.
    My only wish is that they were coated/painted/anodized silver instead of black with the "ECS Tuning" inscription, but I can live then it...
    Just make sure not to go too small (e.g. 5mm) because then they will not have the hub centering rings.
    2007 Audi RS4
    Milltek exhaust//Stasis MS suspension//CPT control arms//TTRS steering wheel//JHM shifter/intake spacers//Apikol trans mount//034 diff mount/rear sway bar/endlinks
    Oct 02 2006
    Wadsworth,OH
    Some like the black and some don't, but black is the color we chose to go with and will likely stick with unless we decide to offer another alternative later on down the road.
    That being said once you own the spacers you can absolutely strip the anodized coating and do as you wish with to them to suit your personal tastes.
    Jason
    Established Member Two Rings totaro's Avatar
    Jul 13 2009
    SF Bay Area
    Great deal - I've had these on for a few months and the car looks great. Lowered with Euro SS+.
    Feb 02 2015
    Clarksburg, MD
    Just placed my order.
    Jul 26 2014
    Upstate NY
    The only thing stopping me from ordering is the fact that some people have had vibration issues with those and recommend MTM spacers. Jason, are these returnable if something like that comes up?
    Senior Member Two Rings IronmanS4's Avatar
    Oct 28 2007
    Speedland, Zoo York
    Quote Originally Posted by DWRS4 View Post
    Ditto on this...
    2022 Audi RSQ8 - Daytona Grey Pearl on Cognac-factory Sport Exhaust- APR Stage 1 93 tune
    2015 Ferrari FF- Grigio Silverstone on Nero
    2015 991.1 GT3- PCCB's-Fabspeed exhaust
    2016 Porsche Cayenne Turbo S (DD )
    Gone..
    2016 Porsche Cayman GT4
    2007 RS4 Daytona-EPL tune
    2003 RS6-Daytona-Milltek DP's -10secS4 tune-
    2001 B5 S4 Stg3+-RS6 turbos
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    Only if u go smaller than 10mm.
    Feb 02 2015
    Clarksburg, MD
    Quote Originally Posted by badbluers4 View Post
    That's what I've gathered.
    Oct 27 2011
    Atlanta, GA
    Yea I have their 15mm on my peelers and they're fine
    Oct 02 2006
    Wadsworth,OH
    Thanks for the order!
    Quote Originally Posted by IronmanS4 View Post
    Ditto on this...
    We've been selling spacers for years and seems majority of vibration issues are from improper installation. 8mm spacers typically cause the most grief as they take up just about all of the factory hub extension and that makes centering the wheel difficult. Once spacers are installed they aren't returnable. If there is physical damage or a defect with the spacers you may return them.
    Senior Member Three Rings Gareth_oau's Avatar
    Mar 13 2011
    Perth Australia
    I'm running 275/30/19s on OEM rims, plus I'm lowers on KW3s to about a 10mm wheel arch gap.
    I'd like to go spacers, but not sure if I will just buy myself lots of rubbing
    APR ECU Upgrade, JHM quickshifter, Milltek catback exhaust, Milltek 100 cell downpipes, JHM lightweight Clutch, Argon CF Splitters, KW V3 Coilovers.
    Veteran Member Four Rings singleframe's Avatar
    Apr 25 2010
    2007 Phantom Black RS4, VW eGolf
    Venice Beach baby!!! 🌞
    Quote Originally Posted by Gareth_oau View Post
    Did you roll your fronts?? You might be okay.
    IG @myRS4 | 2007 RS4 | Phantom Black | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | K&N Filtered | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded | window trim matte black vinyl wrapped
    Oct 27 2011
    Atlanta, GA
    Gotta have spacers!
    May 04 2007
    Northeast
    I have the exact setup as you. Slightly rolled front/rear fenders and have a tiny bit of running on really large bumps. You'll have decent rubbing w/o rolling your fenders, at least without negative camber.
    Glut / Capristo / Baby Seats
    Oct 27 2011
    Atlanta, GA
    Quote Originally Posted by GrandMarkie View Post
    Go 8's on the front. Problem solved.
    May 04 2007
    Northeast
    I have rubbing in the rear
    Oct 27 2011
    Atlanta, GA
    On stock wheels or the AG wheels?
    Mar 13 2011
    Perth Australia
    cheers for that.
    I currently get the slightest rubbing when I bottom out on sudden dips.
    I'm running the Goodyear Asymmetrics too and they have an incredibly large lip protector on them
    Mar 13 2011
    Perth Australia
    by the way, how thick are the advertised spacers?
    Senior Member Three Rings Striddy's Avatar
    Jul 15 2011
    nothing but memories
    It says 4x10mm spacers in the kit
    Ghost
    Mar 13 2011
    Perth Australia
    Quote Originally Posted by Striddy View Post
    It does too
    Established Member Two Rings kmurph's Avatar
    Dec 28 2006
    2008 Audi RS4
    Pittsburgh, PA
    What's the outside diameter of the spacers? Should be 149mm for a RS4. I bought spacers from ECS a few years ago that were supposed to fit a RS4, but they were too small...
    2021 Audi S4 PP - Daytona Gray / Black Optics / S Sport Package
    2008 Audi RS4 - Daytona Gray Ti / Euro Steering Wheel / Milltek Exhaust / H&Rs / Bilstein Sports
    Oct 02 2006
    Wadsworth,OH
    Our spacers are specific to the center bore and bolt pattern. Having spacers specific to the rotor face the spacer seats to for every vehicle would require way too many variations. Some VW's require a slightly smaller size than the standard Audi size which do offer, but if you are searching for a spacer that will be any larger in diameter than what you have we do not have it available. This size fits majority of Audi rotor faces.
    Jason
    Jul 26 2014
    Upstate NY
    Does this cause stress on the wheel? Or does the gap make the setup look a little funny?
    Oct 02 2006
    Wadsworth,OH
    Shouldn't cause any additional stress to the wheel. I don't think spacers make anything look funny, most people don't either. But you're entitled to your own opinion.
    Jason
    Jul 26 2014
    Upstate NY
    Jason
    Although you guys advertise the spacers as being made specifically to work with the OEM RS4 wheels, if the spacers are too small relative to the hub of the wheel, there will be a gap. I was asking whether the gap might be (i) unsafe or (ii) unsightly. I'm just trying to figure this out.
    Oct 02 2006
    Wadsworth,OH
    Please read post #29 in regards to your first question.
    There's no safety concern regarding the gap. I've seen aftermarket wheels that the hub of the wheel doesn't quite fit the entire rotor hub and there's no issue with this.
    Whether it's unsightly is your opinion.
    Jason
    Oct 27 2011
    Atlanta, GA
    Lol not sure what the issue is here....but these are ECS 12mm on my rears (I'm pretty sure although I don't see ECS logo), and they fit fine with OEM wheels.
    Jul 26 2014
    Upstate NY
    Thanks Badblue, that looks good, I ordered a set.
    Oct 27 2011
    Atlanta, GA
    Cool man. Yea as long as you go 10mm and above, you should be fine. No vibrating or any issues.
    Jul 26 2014
    Upstate NY
    I got the 10mm ECS spacers and put them on the car. First of all, the diameter of the spacers is perfect for the RS4: it's 15cm, which nicely matches the hub of the OEM wheel and the size of the rear rotor. There is no gap whatsoever -- the picture in post 28 probably corresponds to an older ECS spacer because I don't have that issue at all. The spacer fits inside the wheel very tightly but all four spacers had a little bit of play around the center bore. I drove the car around town and did not notice any vibrations but I'll take it on the highway tomorrow and see. Overall it looks awesome :-)
    Second, I was surprised to have some rubbing in the front on both sides in sharp turns when driving "spiritedly." The car is stock -- wheels, suspension, tire size, everything. I then removed the two fender liner screws and that seems to have fixed the issue. I think it's because I have Pirelli tires: all four now poke out a little (front and back), they also look more square than the PSS that a lot of people run. Any reason I should be worried about this? Thanks!
    Oct 27 2011
    Atlanta, GA
    Take pics....what size tires?
    Edit:I see you said stock size. Never seen poke on stock size tires and stock suspension before with 10mm spacers.
    Jul 26 2014
    Upstate NY
    Ok, drove the car around, and I get no vibration whatsoever on the spacers. Not sure why I was rubbing but taking out the screw has fixed the issue even on bumps and aggressive cornering so whatever. Bottom line for anyone considering the ECS spacers: they're great, perfect fit for the RS4.
    Oct 11 2007
    Suburbia
    Personally I would go MTM, they are the exact size of the hub, and specifically made for our platforms, not a variety of Audi's. They are also twice the price, but we all drive RS4's here so....
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Custom CAI~Bilstein PSS9s~Girodiscs~JHM shifter~
