Results 1 to 3 of 3
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    difficulty to replace positive battery terminal and wiring
    hey guys, was wondering if anybody knew how difficult it would be to replace the positive battery terminal and wiring. the avant i bought has a positive terminal that looks like battery acid ate through 1/3rd of it so i'd like to replace it.
    thanks!
    Apr 07 2011
    It's actually really easy. I picked up a used on from ebay for like $30-40. The trickiest part of it was getting the connection on and off of the starter. The rest is pretty straight forward. Disconnect from the battery, pull it through the firewall gromet and trace it down to the starter. There's probably a couple zip ties and a couple plastic mounting clips that have to be removed. I believe I might have removed the air box and TIP for easier access.
    Nov 02 2007
    SF Bay Area, CA
    thats what i thought too, but wanted confirmation. THANKS!
