Results 1 to 19 of 19
    Sep 21 2008
    new braunfels
    replacement headlights
    I have condensation, as it seems to be a common issue - I expected to find considerably more threads about replacement headlights, are there any aftermarket options, and if not are OEM quailty replacements, and if not, are there reasonable prices on OEM ?
    Thx
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    You sure you don't wanna just let them air out with the cap open? New headlights are expensive and from what I hear they come sealed now, not glued anymore, so you can't open em up to clear corner.
    Sep 21 2008
    new braunfels
    Quote Originally Posted by badbluers4 View Post
    I'd need more details here - this is a new platform for me, Although I've owned 2 - I never had issues on my much lower miles car, and never really did anything to it. Can they be aired out and possibly cleaned?
    I'm not worried about the cost necessarily, I drive a LOT at night so frankly if replacing them is what has to be done I'm willing to suck it up and do it.
    Oct 27 2011
    Atlanta, GA
    Ok maybe you should post a pic of the condensation. If it's minor, you can always just drive around with the cap on the back of the headlights open to allow it to air out for a day or so...
    I've never heard of condensation being an issue on these cars. If it is that bad, and they do need replacement, OEM is fine. There are also e-codes that are cheaper than OEM, and come clear cornered already.
    If you are not interested in clear cornering or any other mods, then there is no issue with buying new OEM lights. I just wanted to make sure you were aware of that.
    Veteran Member Four Rings ryanhmusic's Avatar
    Aug 05 2014
    jack stands, a power washer, hand tools, bones of my fallen enemies, etc
    Quote Originally Posted by zmw View Post
    search around in the b6/b7 a4 sections and you'll find some more information, but basically -- pull the front lens off, clean and dry thoroughly everything in there, reseal it with RTV and let it dry for a day -- then put the headlights back in and they'll be good as new -- alternatively if you want to replace the lens because of highway pitting, its about $150 for the set. Replacement headlights are right around $2k -- probably worth trying to fix it before you just cut a check for new ones.
    I'm living for the day I can park something Italian inside of my house.
    I had one wild summer on match.com. -some jackass
    01100010 01100001 01101110 01100001 01101110 01100001 00001010
    Oct 02 2015
    B7 RS4, UrS4
    Boston
    I had great luck with the $800 euro headlights seen on ebay frequently. Still not cheap, but cheaper than an importer. Excellent communication from the seller (auto245 or something like that), packed very well, no issues whatsoever since they were installed back in November. I love the sharper beam cutoff of the euro headlights. Clear corners are a bonus.
    Sep 21 2008
    new braunfels
    What are these e-codes you speak of, as long as I keep the movement mechanism and all that shenanigans, that's fine. - Car is at the airport at the moment, I'll post some pics when I get back, but for sure it's not awesome, and every time I wash the car it gets worse, makes me wonder if the caps are off the car, is there a weather protective cap that provides access to the light?
    Oct 27 2011
    Atlanta, GA
    The lights that lucidmatt just posted about.
    If it gets worse each time you wash the car it sounds like that cap is off. (But still can't see how water could get inside that much). Check when you get back to car. It's an opening that you can reach your hand into to replace the smaller bulbs (city light and DRL). It is covered by a flip cap.
    Sep 21 2008
    new braunfels
    Quote Originally Posted by lucidmatt View Post
    Have a link? The euro lights I seem to find say will not fit north american vehicles, and my assumption was because they were angled differently for RHD v LHD but maybe that's shenanigans...
    Sep 21 2008
    new braunfels
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by ryanhmusic View Post
    Where can I source new lenses?
    "Brake last, finish first."
    Senior Member Three Rings prfktgntlmn's Avatar
    Sep 24 2011
    2017%20gmc%20canyon%20sle%20
    Atlanta
    Quote Originally Posted by NYC_Legacy View Post
    Try VXTuning. Email them.
    2007 Audi RS4 Phantom Black/Black Premium
    Oct 02 2015
    B7 RS4, UrS4
    Boston
    Yes, but the link is the non-afs headlights. Here are the ones you need: http://www.ebay.com/itm/Audi-A4-S4-R...ZcStZw&vxp=mtr
    Edit: There is one small (depending on your perspective) annoyance with these headlights. Theyre technically aftermarket so there is no Audi part number, and the pair I received said "Made in Czech Republic" instead of Germany. Functionally though, they are identical.
    Jun 18 2009
    Phoenix, AZ
    I bought a set of these headlights from this ebay'er, one arrived broken internally (got roughed up during shipping it looked like) but he sent a replacement. Very nice headlights, no problems at all for over a year now.
    2017 Camaro SS 1LE
    Oct 02 2015
    B7 RS4, UrS4
    Boston
    Quote Originally Posted by FWP! View Post
    I think he may have learned from your shipment, when I received mine, the internals of the headlight were stuffed full of bubble wrap! Talk about thorough packing.
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Your most cost effective solution is take the lights off, heat gun or oven them and pull the lenses off. Clean them thoroughly and reseal. Look up Joey mod headlights in the b7 s4 section. There are numerous DIY for it.
    ALSO there is a washer that you can replace on the headlights as well that has been known to cause leaking and condensation. I do not have the link readily available but if you search b7 headlight condensation o ring im sure you will find it.
    All this can be done in just a few hours time TOPS over a weekend. I say it like that because you should let the lights dry for a day or two. Entire process without waiting would only take a few hours.
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by prfktgntlmn View Post
    Thank you Sir
    Jun 18 2009
    Phoenix, AZ
    Mine both came with a lot of bubble wrap crammed inside them, but one was broken. The frame broke that controls the movement of the projector housing, I posted pictures of it in another thread.
    But like I said, he was good about getting it replaced.
    2017 Camaro SS 1LE
    Senior Member Three Rings Gareth_oau's Avatar
    Mar 13 2011
    Perth Australia
    ECS carry OEM, plus do Euro lights for USA
    https://www.ecstuning.com/Audi-B7_RS...ng/Headlights/
    APR ECU Upgrade, JHM quickshifter, Milltek catback exhaust, Milltek 100 cell downpipes, JHM lightweight Clutch, Argon CF Splitters, KW V3 Coilovers.
