    Established Member Two Rings kr3w45's Avatar
    Mar 19 2014
    02 a4, 06 a4, 09 a4, yamaha r6
    Boston, MA
    Quick Oil Filter Question
    Went to change the oil and filter on my girlfriend's 2.0t. Unscrewed the filter (it was fram from a quick lube shop) went to grab the new filter and the threads were different so I immediately assumed I got the wrong filter and put the old one back on.
    Turns out I had the correct filter
    It looks like when I loosened the fram filter, the threads and plastic seal stayed into the filter housing- and the filter with a smaller thread unscrewed from the end. Has anyone run into this before? I've changed a thousand oil filters and can't remember anything like this.
    If I had access to the car I would just look and figure it out, but I only see the car every few weeks or so
    Automate your Dealership: www.DealerScience.com
    Automotive Technician @ Amherst Autoworks
    B7 A4 - Frankenturbo F23L
    B8 S4 Stage 2
    Established Member Two Rings theSaint024's Avatar
    Jul 16 2014
    SF CA
    Yes I have once out of 4 oil changes. Simply use channel lock pliers or the like to get the rest of it off. Alarmed me too when it happened but you don't need that part anyway. Happened to my Mann filter so it probably happens to all of them some time. Why are you using Fram anyway?
    2013 allroad - ibis white P+ - The answer is... "it's an allroad bro."
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    I've had the nipple stay in the block once in 5 years. It came out easily. I called my dealer SA and they see this occasionally also. By the time I got back to the car and it had cooled a bit more, the nipple spun out by hand. Just grab it with pliers.
    2011 A4 Avant
    Mar 19 2014
    Boston, MA
    Thanks! I don't use fram, she brought the car to a quick lube place who used it. It's been probably 15k since the last oil change so that's probably why the nipple is stuck in there. Appreciate the quick responses!
    B8 S4 Stage 2
    Active Member One Ring zchristopher10's Avatar
    May 04 2015
    austin Tx
    Yeah same thing happened to me on my last oil change, thought I got the wrong one too but then took a second look at what was going on.
    Sent from my SM-N920T using Tapatalk
