1995 Audi S6 Quattro
156,XXX Miles
$6000 obo
Pearl White
Ecru Interior
Original Wheels
Tinted Windows
Tow Hitch
6 Disk Changer in Trunk
http://imgur.com/a/ztoJH
Now if you don't know, I'll introduce this car to you. This is the rally winning engine tucked into Audi's flagship model for this year. The S6 was only offered in 1995 (in the USA) and was the last revision of the legendary Audi 5 Cylinder powerplant, As such it was their most refined and powerful version, it is the 20 valve turbocharged unstoppable engine. These engines are highly sought after and capable of VERY high horsepower. The S6 is a luxurious but speedy car, packed with Recaro front seats with leg extensions for those of us with long legs.
As for this SPECIFIC example, it has what is considered low miles for its age, (the engines are well known for 300k+). We have gone through and taken care of a lot of deferred maintenance, while this car was subjected to regular oil changes, lots of the engine specific things weren't taken care of, here is the list of what has been replaced:
Original coil packs have been replaced with OEM replacements
POS (power output stages) have both been replaced
O2 Sensor
Spark Plugs
Strut mounts
FULL Timing belt service (ALL Belts, Water Pump, Tensioner bearing, ect)
Coolant Flush
Brake Fluid Flush
Fuel Filter
Air Filter
Cleaned Maf
IAT sensor
Engine Mounts
Many interior trim bits known to show wear
Passenger Side Front Axle
Various Boost hoses/Vac Lines
All lower door trims
Coolant "T"
Valve cover gasket
Brake lines
Car leaves no puddles or drips after being parked for days in the same spot!
Now after all this work that had been neglected 20+ hours were spent detailing the car, complete clay bar, cut and buff, along with under hood cleaning, and LOTS of hours spent scrubbing seats back to their proper original color and cleanliness. This car is now ready to be driven anywhere! This car while some aspects were behind on maintenance is VERY solid now. Between me and my partner on this car we currently have 5 other Audi 5 Cylinders. This one pulls stronger than any of the other stock turbo ones we have, it is VERY healthy and puts you back in your seat as you push the gas in second. It is a great car that will put a smile on your face when you drive it. This car needs nothing, and shouldn't need anything but oil changes for at least a year. It is located in North Salt Lake Utah and a clean title is in hand. Test drives are welcomed, but be warned, you will want to buy it after driving it!
Text messages are preferred to set up calls, or emails: 801-645-0825 or [email protected]
List Date: 4/5/2016
For more info, click here to view the original listing: 1995 Audi S6 Quattro
This item is no longer available.
