    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Winter wheels/tires and TPMS
    Those of you who swap out there wheels/tires for winter wheels/tires what do you guys do about the TPMS? Did you get the warning light and is there a solution to it?
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Senior Member Two Rings JohnnyUtah787's Avatar
    Oct 03 2015
    Illinois
    S3 doesn't have TPMS per say. Just pump the tires to the correct pressure and reset the system in MMI.
    2015 Audi S3 - Glacier White, 19" Performance Package, B&O Sound System, LED Lighting Package, Black Optics grille, Black optics fog grilles, Black powder coated OEM exhuast tips, Satin black 19x8 ET45 Neuspeed RSe10 wheels with Continental ContiSportContact 5P tires (summer set-up), OEM 19x8 ET49 double 5-spoke wheels with Pirelli Winter Sottozero 3 tires (winter set-up), 15 mm ECS spacers all around, Emanuelle Design springs, 034 Motorsport dogbone mount insert
    Apr 27 2010
    West Chester PA
    TPMS is handled by the wheel speed sensors, nothing in the wheel/tire. just reset with the new setup and drive.
    2015 S3 Daytona 1 Package | Unitronic Stage 1+ ECU | Unitronic Stage 1 TCU | H&R Sport Springs | CTS Intake/ Turbo Inlet | APR Turbo Muffler Delete | OEM Resonator Delete/ Flap Mod | Welded Magnaflow Tips | 19x8.5 ET 45 Forgeline ZX3R with 245/35/19 Conti DW | 20% Tint
    Aug 28 2013
    Thanks, I did not realize there were no sensors.
    Mar 15 2016
    Denver/CO
    Yes, good info, I had no idea!
