Hello to everyone in the forums, and i will start by saying thank you in advance to anyone who takes the time to try and help me out.
I recently graduated and wanted to treat myself hence i bought a 2011 Audi A4 (B8) 2.0 TFSI S Line Quattro Black Edition. It is a CATEGORY C insurance wright off, however the engine and transmission is in perfect working order. The car had been fitted with the face lift during repair im assuming. While buying the trader assured me that the issues that were present is to do with coding and they are waiting on the machine so they can correct it. Hence i took a leap of faith and bought the car (mistake number 1) under the valid assumption that they would sort the issues out for me at a later date. I'm sure you can see where this is going.
A few days of driving and the controls for the AC/Heating, Heated Seats, stops working (only front and rear defroster and AC comes ON and OFF). A few more miles and after a car wash the Electronic Parking Brake stopped working (paking brake malfunction warning). The light control switch doesn't correspond to the actual lights, for example in the 'off (0)' position the front DRL are on, In the 'DRL' position the front DRL are off and rear DRL are on. On full beams only the headlamps come on and no DRL.
Ive managed to get a friend to run a diagnostic and get the full list of codes and fault codes. Which i have attached below. I will attach pictures to better explain exactly whats going on. If there is any information that is needed i am happy to do all i can to get it. I would really appreciate any help any of you can offer.
Also the car had already been fitted with the face lift when i purchased hence i dont know what parts where used, what was changed or added.
PLEASE CAN I JUST SAY THAT I AM COMPLETELY NEW TO ANY OF THIS SO PLEASE WOULD YOU BE KIND ENOUGH TO EXPLAIN CLEARLY FOR ME WHAT YOU NEED FROM ME OR WHAT I NEED TO DO.
Thank you once again for any help any of you can offer.
Tuesday,05,April,2016,05:24:48:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 5F 62
72
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CL0MA-CDNC) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 P HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H20 0009
Revision: E1H20---
Coding: 0104000C240F0160
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM02TFS8K2907115P A01011
ROD: N/A
VCID: 3C6E2433E66B5E620338425-8068
No ASAM data for: "EV_ECM02TFS8K2907115P" (AU48)
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8K1 927 156 G HW: 0B5 927 156 F
Component: 0B5 20TFSIRdW H10 0008
Revision: --H10--- Serial number: 0000001298
Coding: 000001
ASAM Dataset: EV_TMCDL501 A02087
ROD: N/A
VCID: 39603D27E9596B4A185EA39-806C
No ASAM data for: "EV_TMCDL501" (AU48)
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BG HW: 8K0 907 379 BG
Component: ESP8 quattro H04 0020
Revision: -------- Serial number: --------------
Coding: 090500
Shop #: WSC 06325 123 12345
VCID: 7F14133FB7FD85FA669AAD1-802A
2 Faults Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Date: 2016.04.04
Time: 22:07:57
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x002E
Hex Value: 0x0698
Hex Value: 0x00FF
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Date: 2016.04.04
Time: 22:07:57
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x002E
Hex Value: 0x0698
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CC HW: 8K0 907 064 CC
Component: BCM2 2.0 H05 0435
Revision: 00002001
Coding: 011100
VCID: 73FCCF0F8BB5D19A12E2211-8026
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG
Component: KLIMA 3 ZONEN H08 0160
Revision: D1000000 Serial number: 01130720090696
Coding: 34360000
VCID: 77E4FB1F9FCDBDBA2ECAF51-8022
4 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 6
Reset counter: 6
Time Indication: 0
Date: 2016.04.04
Time: 22:03:47
01020 - Water Pump (V36)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
Date: 2016.04.04
Time: 22:03:47
Freeze Frame:
Voltage: 13.80 V
Temperature: 102.0°C
Current: 0.000 A
Voltage: 2.00 V
Voltage: 0.00 V
Bin. Bits: 00000000
RPM: 680 /min
Load: 0.0 %
00256 - A/C Pressure/Temperature Sensor (G395)
Freeze Frame:
Fault Status: 01101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
Date: 2016.04.04
Time: 22:03:48
Freeze Frame:
Temperature: 17.0°C
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
Date: 2016.04.04
Time: 22:03:48
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000001080645
Coding: 260050914034AF010001000300001D0D0F1D43080201014100 0000
VCID: 3C6E2433E66B5EE20338425-8068
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 210511 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
3 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 121
Reset counter: 6
Time Indication: 0
Date: 2016.04.04
Time: 22:08:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 92
Reset counter: 6
Time Indication: 0
Date: 2016.04.04
Time: 22:08:00
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
Date: 2016.04.04
Time: 22:03:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 AA HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0081
Revision: 11001001 Serial number: 12501114603100
Coding: 100103
Shop #: WSC 00000 000 00000
VCID: 78E6F82392D3B2C227D0FE5-802C
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 L HW: 8K0 959 655 L
Component: AirbagVW-AU10 H44 0610
Serial number: 003JMD0C3L6D
Coding: 30533435363030303030554A3052384B3053
ASAM Dataset: EV_AirbeACUVWAUDI010 003010
ROD: N/A
VCID: 469A46DBA8A714B265DCD0D-8012
Subsystem 1 - Serial number: 6334MSME6011561A3
Subsystem 2 - Serial number: 6344MSME601317541
Subsystem 3 - Serial number: 6352QSME3E1D4268S
Subsystem 4 - Serial number: 6362QSME477D3B3E/
Subsystem 5 - Serial number: 63732SME34063A50U
Subsystem 6 - Serial number: 63832SME650E2070Y
No ASAM data for: "EV_AirbeACUVWAUDI010" (AU48)
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KEF0004G
Coding: 000036
VCID: 3D682937FD7157EA3406779-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 981 B HW: 8K0 920 981 B
Component: KOMBIINSTR. H30 0258
Revision: 00000000 Serial number: EJA222K5C
Coding: 2F07090002002600010000
VCID: 32720A0B342F9892D994FCD-8066
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E11510812D
Coding: 00C303
VCID: 031C9FCFDB15E11A0242F11-8056
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
Date: 2016.04.04
Time: 22:08:00
Freeze Frame:
Bin. Bits: 11111
Voltage: 12.70 V
Count: 6
Text: FF30746D00820100
(no units): 29689.0
Raw, Form. N/A: 000 130 001
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011C02205001410001
VCID: 53BC6F8F6BF5B19AF222411-8006
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0150728479
Coding: 011B062200B904808030013280000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34804006439301
VCID: 7AE2E22BACDFA0D251A494D-802E
1 Fault Found:
02753 - Inside Microphone (R74)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
Date: 2016.04.04
Time: 22:03:54
Freeze Frame:
Voltage: 14.00 V
Temperature: 41.0°C
Temperature: 45.0°C
Bin. Bits: 00000100
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
VCID: 52B26A8B54EFB892F9545CD-8006
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000415530
VCID: 347E0C13CE3B96A2CB68EA5-8060
1 Fault Found:
03200 - Switch for Electric Parking Brake (E538)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 3
Reset counter: 45
Time Indication: 0
Date: 2016.04.04
Time: 22:08:01
Freeze Frame:
Voltage: 12.80 V
Count: 38
Speed: 0.0 km/h
Hex Value: 0x02E0
Hex Value: 0x0001
Hex Value: 0x0101
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000004
VCID: 39603D27E95967CA185EA39-806C
2 Faults Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Time Indication: 0
Date: 2016.04.05
Time: 03:24:50
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Time Indication: 0
Date: 2016.04.05
Time: 05:08:15
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 061 F HW: 4G0 035 061
Component: Radio U DAB H52 0098
Revision: AB001007 Serial number: 470EX0B7518244
Coding: 010103010000000001
VCID: 2056F0436AC31A023F20B65-8074
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T2 035 666 H HW: 8T2 035 666 E
Component: H-BN-EU H52 0146
Revision: -------- Serial number: 475E70B7568575
Coding: 010101000006A1ED01000B1E000000030000
VCID: 409650C38A833A025FE0165-8014
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
2 Faults Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 6
Time Indication: 0
Date: 2016.04.05
Time: 04:31:59
Freeze Frame:
Bin. Bits: 00000000 10000000
Bin. Bits: 00000000 00000000
02169 - Front Right Microphone (R141)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
Date: 2016.04.04
Time: 22:03:52
Freeze Frame:
Voltage: 14.20 V
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1501
Coding: 010C02204001210001
VCID: 56BA969B7807A4B2153C60D-8002
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H06 1501
End-------------------------(Elapsed Time: 03:10)--------------------------
