Results 1 to 15 of 15
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Can i tighten this rear suspension bolt with the car on the ground?
    Was wondering if i could tighten this bolt with load on the suspension? I heard a clink after picking up my car from a shop and looks like they forgot to tighten up the top strut bolt
    Feb 09 2016
    Palm Beach Gardens, Florida
    I would recommend picking the car up.
    Dec 10 2013
    Borden, Ontario, Canada
    Jack it up a bit then wrench away
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jul 04 2012
    Woodbridge, VA
    I've heard it's better to preload the suspension always before tightening anything back. Dunno if that applies to the control arm but I practice that method
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    That bolt really doesn't matter as that bushing will never rotate. Tighten away.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Aug 04 2014
    Gloucester MA USA
    Ok thanks guys, my car has a reiger kit on it so jaking it up without a special jack is a no go so that would be nice to be able to keep it on ground. But after trying to get to it it seems very had to do with wheel on. So im prob guna have to bring it to the shop down the street.
    Its always something with my cars lol
    Aug 04 2014
    Gloucester MA USA
    Now just realized when i went to snug it up before i left to go to that they used a different bolt/nut on the strut to braket bolt.
    One nut has a washer built into it and one is just a nut.and pne tip pf the bolts flat while the other is pointed. What goes where?
    I bought fromt and rear ecs suspension instalation kits. So the shop had all new bolts to work with.
    It would be awsome to figure out if this will be fine or if i should move bolts around to the rifht location. What nut and what bolt should be used on this loction?
    Aug 04 2014
    Gloucester MA USA
    I found out where each bolt/ nut goes. Looks like a fron nut in the rear. And a bottem bolt on the top on one side?
    Obviously i should go back and put thinks where they belong? Or shouldo leave them since they were all stretch bolts that were new.
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    All bushings need to be tightened when the suspension is preloaded. If it is not, the bushing will be twisted all the time, and it breaks sooner. Take the wheel away, and put something under the suspension arm and put the car on top of that. Then tighten the bolts. (loosen first when lowering).
    Dec 10 2013
    Quote Originally Posted by okkim View Post
    Not for the strut bushings because they do not physically move
    IG: 24_et
    Sold:
    RIP:
    Aug 06 2008
    Canadia
    Quote Originally Posted by slow ride View Post
    This
    Everything else needs to be tightened with the suspension loaded up or you will destroy your bushings in a matter of months
    the B5 S4 is like the mafia... there is only one way out!
    Aug 04 2014
    Gloucester MA USA
    Thanks guys!
    Dec 07 2004
    Finland
    Quote Originally Posted by Bordom View Post
    What bushes are you meaning? The shock absorber upper bush/bolt?
    Dec 10 2013
    Yessir
    IG: 24_et
    Sold:
    RIP:
    Dec 07 2004
    Finland
    Ok. Then that is true, no need to put preload :)
