Results 1 to 4 of 4
    Apr 05 2016
    eau claire, wi
    Exclamation i need some help here please (electrical issues)
    01 A6 4.2 auto
    ok so the issue is my climate control (no display at all and no functions work), heated seats, rear window shade and manual control of my mirrors (passenger mirror still tilts when trans is placed in reverse) all suddenly quit working and my radio dose not shut off when the ignition is turned off (this may not be related as my drivers door latch sensor is on the fritz). I have checked all the fuses i can find (under hood panel in the "ecu box", main fuse panel left side of dash and the two i can see under the hush panel). i am usually good at finding electrical problems and i know how to properly use a DMM and have been using one wile checking all my fuses. i have a spare comfort control module but i am hesitant to install it as i am skeptical it would be supplying power to my climate control... also i have no wiring diagrams to work from and as you know audis wiring is far from straight forward so... i really need some help here guys lets hear it
    also if anyone has some wiring diagrams i would be very grateful!
    Apr 05 2016
    eau claire, wi
    I know its a complex issue and its unlikely someone will have a definitive answer but if you think you have anything to help point me in the right direction please give it a shot!
    Sep 11 2009
    NE
    Sound like comfort module to me actually. Message stratocu510 on quattroworld forums for access to service manuals that include electrical diagrams.
    Apr 05 2016
    eau claire, wi
    I will swap out the comfort control module when I get some free time and see if that's it. I will also check the harness wile i am down there.
    Sent from my SM-N910V using Tapatalk
