Results 1 to 2 of 2
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    Traction Control Light - Brake Light Switch?
    Hey Guys,
    I've noticed over the past few weeks, at times my traction control light will pop up intermittently for what appears to be no reason:
    Doing a quick scan, I see the following codes in the ABS module:
    Did my due diligence, and found that it is linked to possible brake light switch via the Ross-Tech wiki:
    Ross-Tech Link:
    http://wiki.ross-tech.com/wiki/index...it_Malfunction
    Since this is happening intermittently (few times a week), just want to confirm if it is the brake light switch....or something else going on?
    Thanks in advance for everyone's time and help, it is greatly appreciated!
    Thanks,
    Asif
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Veteran Member Three Rings Lauri0112's Avatar
    Jan 29 2015
    Estonia
    Well the brake light switch is a part that fails often.
    Quite cheap as well. Just replace it and see it the problem goes away.
    I had the same code at one point, new switch solved that problem. ( as far as I can remember, it was the same 00526. )
