Results 1 to 8 of 8
    Established Member Two Rings Shortrun's Avatar
    Dec 21 2015
    Ontario
    No reverse on 6 speed
    Problem started a couple weeks ago where the gear shifter was stuck, felt like it was frozen.
    Today it feels normal, all forward gears are ok.
    But it does not go into reverse. The shifter will push down and will move to the correct place for reverse but as soon as i let go it just pops over to where first gear is.
    Any help please.
    Car is a 2004 1.8t
    Dec 21 2015
    Ontario
    I tried finding reverse with the motor off and it went right in.
    Started the motor and the car backed up ok. Went forward and back several times, no problems.
    Very odd!
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Sounds like the screw holding the linkage to the shift knob may be a little loose. JHM had a decent video explaining adjustment. It isn't too difficult getting to the screws holding things together.
    Sent from my DROID Turbo 2
    Dec 21 2015
    Ontario
    Thanks for mentioning JHM
    A little googling and I found some really well produced videos that will help with removing the shifter. Which is the first step in determining what is going on.
    Aug 27 2013
    Philly
    Quote Originally Posted by Shortrun View Post
    Before removing it, try adjusting it. When I did my clutch job my shifter was all sorts of messed up. After disconnecting and reassembling it, everything was good again.
    Dec 21 2015
    Ontario
    Thanks SJ
    I need to find a video of someone doing the 6 speed transmission adjustment.
    Or a written procedure.
    Apr 07 2011
    Dec 21 2015
    Ontario
    Perfect, thanks. here is to hoping that is what my problem is.
