Results 1 to 4 of 4
    Nov 29 2012
    pomona ca
    Need help with p0130, poor idle
    Hi everyone , I'm having a weird issue that I can't figure out. So I'm turning to you guys for advice.
    I bough an 01 a4 turbo Quattro.
    Looks like previous owner did all kinds of weird stuff to it
    Info:
    Car had 30lb Injectors and a split second boost controller. On a stock computer. Car was running like carp. Went back to stock injectors and got rid of the split second box . Car drives decent now. But I do have a p0130 code (malfunction with primary o2)
    So far I have:
    Tried 3 other o2s from working cars
    Tried 2 mafs
    Rewired the 02 all the way to ecu
    Boost leak test. No leaks all check valves working
    I have vcds but the pc is at the shop now getting a new screen .
    My generic scanner shows 0v during open loop of course , but when,it switches to closed loop the voltage starts to drop and stays at -1.4 v and car starts to shake.. anyone had similar issues? Any suggestions?
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I had the same code, put a new one in, car runs great. Then a few days later i got this code again so i just cleared it. It hasn't come back in over a week now. My car idles normally but once in a while the rpms dip to 500 then back up to 800. Then it idles fine. But I can tell when the code comes back on bc ill start getting an unusual amount of smoke out of the tail pipe, I have a test pipe so its worse then normal. Does your car idle normally or is it rough?
    Nov 29 2012
    pomona ca
    I tried my friends ecu and I checked with the scanner and the voltage is a bit more steady. Stays around 0 and climbs as I accelerate. As far as idle it's rough for about a minute but as soon as the code sets seems to idle better as if it's running of a predefined map... just order another ecu hopefully that fixes my issue. I'll report back soon
    Jul 14 2015
    New Jersey
    I am having the exact same problem as davdraco1 its driving me nutts I made a thread byt didn't get many replies.....
