Results 1 to 16 of 16
    Nov 28 2015
    Montreal, QC
    Found an affordable 18' LW wheel, but center cap won't fit.. suggestion?
    Heyy!
    Bought my PSS 245/40/18 tires today. Went to buy my rims I was looking for and ... huge bummer !! The company said if I get the 18x9 +30, the center cap will fit. But some people on here reported that I should/could be getting rubbing issues. The 18x9 +40, which people on here have reported to be without any issues whatsover and a safe fitment, can't be fitted with the center cap.
    1) Can I fit another center cap ? custom one ? I don't really feel like driving a luxury sedan without center cap..
    2) Any other LW wheels under 1k$ as a suggestion !?
    Theses wheels were under 1k$ CND, warranty for 3 years, flow-formed 18.6lbs, exact replica design of the AG M580.
    By the way, my car is OEM as of now, but already bought Bilstein PSS10. I plan on setting the height to the maximum possible as my goal is to have a ''Planted feeling'' '' on rail'' than for the lowering aspect of the coilover. so the closer to stock possible will be just fine.
    Thank you folks! Happy modding ! :)
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    I wonder where to find center caps also for my Renn Motorsports wheels
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    It seems like an entrepreneur with a 3D printer would be all over this need. Would it be difficult to pull the specs from a wheel and print/paint center caps?
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    You have a link to these LW wheels?
    Murdered B8.5 S4
    Build Thread
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by The Fat Kid View Post
    Good Idea! Is the oem cap too big or too small?
    Veteran Member Three Rings VenturiRS's Avatar
    Dec 27 2008
    Quote Originally Posted by silverf0x View Post
    This...I want some new 19s that I don't have to budget for and eat granola bars for breakfast, lunch and dinner for---and my OEM Peelers are starting to lose the clear coat...yay NE.
    B8.5 Estoril Blue S4 | P+ | DSG | SD | ADS | B&O | CF | Nappa | Advance Key | CF Badges
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    LINK!
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Nov 28 2015
    Montreal, QC
    they are the FAST FC04A.
    Dec 14 2015
    Montreal, QC
    18x9 +40 ?
    Murdered B8.5 S4
    Build Thread
    Nov 20 2014
    New York
    Yea the center bore on those is 72mm ours is 66.xx
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by waxxonMTL View Post
    Heyy!
    Bought my PSS 245/40/18 tires today. Went to buy my rims I was looking for and ... huge bummer !! The company said if I get the 18x9 +30, the center cap will fit. But some people on here reported that I should/could be getting rubbing issues. The 18x9 +40, which people on here have reported to be without any issues whatsover and a safe fitment, can be fitted with the center cap.
    The issue likely isn't with the center cap itself, so a modified or custom one probably won't work either. More than likely the hub extends too far through the wheel centerbore, and there is not enough space to physically fit a center cap there without shaving down the part of the hub that protrudes through (which I wouldn't recommend).
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Dec 14 2015
    Montreal, QC
    Quote Originally Posted by jran76 View Post
    Exact same thing happened to me with my Avant Garde M550. I was missing maybe 1 or 2mm to "clip" the center caps enough so that they wouldn't pop out. So the options were buying 3mm spacers or trim.
    I didn't had the chance to actually choose because the shop installing my wheels went ahead (without my actual consent) with the trim and it worked perfectly. After looking at it I was fine with their decision since it was merely a quick buff which didn't cause any structural issue, basically only aesthetic was affected..
    Murdered B8.5 S4
    Build Thread
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Does the wheel not come with a center cap that could be modified/painted or an Audi sticker/emblem put over it?
    Nov 28 2015
    Montreal, QC
    I'm surely not the first to have this problem right ? :)
    I spoke again with the garage and they said ;
    1) Check on audizine if a +30 is going to rub on a 245, 1/2 to 1 inch drop.
    2) Fit a 3 or 5mm spacer to allow the cap to clip. This way I would pick the +40 with a 5mm. I would be +35 right in the middle.
    Spoke with this issues with a friend of mine and he said he's running +35 18x9.5 on H&R spring and have no issues with rubbing. Said, worse, you will remove the screw in the fender.
    Sep 21 2016
    Alberta
    Did you ever get this figured out? I'm looking into these wheels as well
    Nov 28 2015
    Montreal, QC
    Quote Originally Posted by Kirk M View Post
    the center cap fit lol.. never had to do anything about it.
    S4 B8.5 no track, just enjoying spirited driving.
