Results 1 to 8 of 8
    Senior Member Three Rings itlnstallion818's Avatar
    Apr 28 2013
    Columbus, OH
    Bluetooth/wireless OBDII code reader?
    I have Ross-Tech VCDS for running codes and clearing, etc, but my car is almost 100% mechanically stock with the exception of an intake and an 034 HFC. I have codes P013E and P013F popping up as a result of the HFC and no stage II. Is there a wireless solution that would make it easy for me to at least SEE what codes i'm throwing instead of hooking up VAGCOM every time? I just want to keep an eye on everything and make sure those are the only two codes i'm throwing on a daily basis? Thanks in advance.
    2013 Scuba Blue A4 | S-line Prestige | AVG M590 | K&N Typhoon | VCDS | 034 HFC
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    http://www.amazon.com/Bluetooth-Diag.../dp/B0051CAE1C
    I use this one, and have Carista and Torque installed. They will both get faults for you.
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    A Bluetooth or Wi-Fi OBDII reader.
    If you have an android device, you will most likely need a bluetooth adapter. If you have an iOS device, you will most likely need a wi-fi adapter. Amazon and ebay has plenty, just make sure you pick up the right on for your device.
    After you have the adapter, all you need is the app on your device. For android I recommend Torque Pro. For iOS I recommend OBD Fusion. There are many other options as well.
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by itlnstallion818 View Post
    Why not get the stg2 tune ?... It's Almost impossible to run a HFC with the programing for it.. Torque pro linked to my Bluetooth obdlx module works flawlessly... Real time gauges as well...
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Apr 28 2013
    Columbus, OH
    you guys are awesome! I'm waiting on stage 2 because I already had to fork over $10k for a new longblock because of a faulty injector that grenaded my engine while I had stage 1 and was flagged. I don't want to tempt fate with another tune until I'm out of the new warranty.
    Established Member Two Rings kiw1's Avatar
    Mar 29 2016
    2022 BMW X5
    Santa Monica, CA
    Might be a stupid question but how do you guys actually use your Bluetooth readers? Just for when the check light comes on or on a more regular basis?
    2012 A4 Avant - APR Stage 2, JHM FMIC, EuroCode Test Pipe, Front and Rear Sway Bars, Bilstein PSS10, CR15, ECS Turbo Inlet Hose, aFe, RS Front Grille
    Sep 03 2012
    Lehigh Valley, PA
    I totally forgot that!.. Ugh.. I rember before you even had the stg 1 tune.. I'm still up in the air on which to go.. I know giac is working on a hfc stg 2 as of now.... They are claiming 300 hp flywheel on 93 on their stg 1... And 320 flywheel on their stg 1 e85...
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Are you running a spacer for the second O2 sensor? Some people swear by them eliminating the CEL.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
