Results 1 to 10 of 10
    May 11 2015
    Georgia
    Grinding noise on cold start
    Anyone else dealt with a grinding noise when turning on your car from a cold start? Probably there just for a second or so, much more noticeable from outside or windows down, and only when turning on the car after sitting overnight. I mentioned this to the dealer last time I was in for maintenance and they couldn't duplicate it.... but planning to bring it back up when I get my next oil change.
    2013 S4 Monsoon Grey 6mt
    Oct 27 2009
    Miami, FL | Boone, NC
    Yes, if you mean immediately after it starts, I believe I know what you are describing. Mine does it as well, but I don't think every time...
    Weird noises during cold start are a given.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Veteran Member Three Rings Reckon's Avatar
    Jul 16 2015
    St. Petersburg, FL
    Could just be the starter sticking - not uncommon in cold weather (not sure if this would be an issue with Audi but was very common in Hondas I dealt with)
    2014 Estoril Blue Audi SQ5 Prestige
    2017 Ebony Black Jaguar F-Pace Prestige
    Senior Member Two Rings UberBrute's Avatar
    Jan 05 2014
    E91 BMW 328xi 6MT
    Connecticut
    does it sound like a rattle from the back of engine, and it only happens on completely cold starts? If so it might be your chain tensioners. There is a tsb for it, but it only applies if you hear the noise for more than 1 second. I took mine in to have it checked and they confirmed mine was normal. The noise should only last between a second or less.
    http://www.audizine.com/forum/showth...rt-V6-3-0-TFSI
    Also, if you hear a rattle from your exhaust when holding the rpms right around 1000-1100 then you could also be getting an rattle from bad resonators in the mid-pipe. I recently had both mid-pipes replaced because of this.
    SOLD 2013 Audi S4 | 6MT | Estoril Blue Crystal | Premium Plus | MMI Nav Plus | Sports Differential | Carbon Atlas Inlays | Alcantara inserts | 19" Peelers |
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    ^^ this.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    May 11 2015
    Georgia
    Thanks for the responses guys. Yeah it only happens on the first start of the day, hoping that it's just normal operation.
    But I did check out the link for the TSB UberBrute posted and the sound is just like in that video. Except that on the TSB it says that the sound must happen after the first start of the day. Well, I'll bring it up to the SA... can't hurt. Thanks again all.
    Oct 27 2009
    Oh mine doesn't sound like the video. And the noise starts about a second after the engine starts, not immediately upon start.
    I have a '16, so I hope I have the latest revisions of everything...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Senior Member Two Rings jmaddr's Avatar
    Jun 19 2013
    United States
    There is a TSB for the cam tensioners. It's a superficial noise and not one to worry about (so says the TSB) but they have developed new ones to overcome.
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    Mine sounds like a maraca if its too cold out for a brief second after startup. I figured it was the 0w-40 not doing its job during below freezing temps.
    Jun 20 2015
    NC
    It's the cam chain tensioners 100%. Like already stated. The bulletin says no harm will be done, but they have developed new ones to address the issue.
