I had upper oil pan leak. Removed lower and upper, and oil pump.
Now dry, but getting blinking red oil can low oil pressure warning.
I think pressure is actually low (a bit more valve clatter than normal), nut just a sensor malfunction.
I don't think the pump died in the day it was out.
Also don't think that I applied too much goop that is now plugging the oil pump pick up.
What else cold cause it?
May dislodged/bad O ring in the oil pump pipes? There were 4 O rings IIRC (reused)?
Other suggestions?
Getting ready to pull lower oil pan again to get to pump (darn).
Any suggestions/input appreciated.
