Results 1 to 14 of 14
    Senior Member Two Rings WeekendDriver's Avatar
    Oct 02 2015
    Audi A4 B6 1.8T (BFB), 1972 Fiat 124
    πŸ‡ΊπŸ‡¦
    Which tire size for softest ride on 8.5Jx18 wheels?
    I'm about to buy a set of 8.5Jx18 wheels (ET 45 but I can do some reasonable spacers if need be) instead of my bone stock 16-inch ones, and I need to get some tires, too. And the thing is, I want the highest possible tire profile for softest ride (i. e. as much air cushion as I can get). And I'm also not sure which tire width fits 8.5J best. I do want the tire to be a tad wider than the rim so that when I park alongside a curb I'll scratch a tire and not a rim.
    So my question is two-fold:
    1. Which tire width to get for a 8.5J-wide rim?
    2. More importantly, what's the highest possible profile that will fit B6 without rubbing on a 8.5Jx18 wheel? Let's assume regular suspension, not the sport one.
    Here's what I know. The factory size for R16 is 205/55, and I know for a fact 205/55 R17 also fits without problems. A couple folks run that setup. 205 x 55% = 112.75 mm tire height. But that's R17, and I'm about to run R18. To maintain the same outer wheel diameter, I need the tire profile to be half an inch shorter. So, 112.75 - 25.4/2 = 100.05 mm. So I should aim for 100 mm tire profile height. That would be, for instance, 230/45, or 250/40. Unfortunately, the 5% profile height stride doesn't allow for fine tuning.
    Thoughts, advice? Are my calculations sane? They do not account for the fact the my wheel is at least an inch (or even 1.5") wider than the R17 wheels folks run with 205/55...
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by WeekendDriver View Post
    Check out this site : http://www.willtheyfit.com/
    It'll help you with your tire sizing.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Oct 02 2015
    πŸ‡ΊπŸ‡¦
    We need to account for the specific wheel well dimensions and shape for best result, but thanks, neat site! I like how it visualizes ET. But, again, it's all just a game of numbers without taking note of the specific car.
    I mean, if I were to input my stock 205/55 R16 dimensions, I would never know that 205/55 R17 would also fit perfectly.
    Apr 01 2011
    B5 on jack stands
    charlotte
    40 or 45 *235* series tire if you want smoothness/comfort.
    you could probably go to a 50 or 55 but.....it would not look good at all.
    powered by
    Hot Boi parts
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    If you are worried about curbing I would recommend buying a tire that has a small rubber lip as a feature specifically for this purpose as opposed to buying a tire that is a "tad wider" than the wheel. Otherwise just measure how much space you have to play with and play around with any of a number of different online resources for tire sizing such as 1010tire.com. I would guess 235/45 will fit without issue, 235 is a good middle of the road size for a 8.5 wheel, 45 sidewall is only a little more than stock and likely your best option for a little more comfort without looking funny.
    Oct 02 2015
    πŸ‡ΊπŸ‡¦
    Quote Originally Posted by demonmk2 View Post
    That's not a concern. If anything, I like the brutal look of big fat rubber you can use to traverse some mud with fearlessly :)
    I'm a bit skeptical as to whether 235/45 would fit rubbing-free in the front (and even more so about 50), but if it would, that would be awesome! Almost no sacrifice relative to my current setup.
    Quote Originally Posted by MacFady View Post
    I've heard about those, but never seen such a tire myself (I think). What's the name for that, how can I search for it?
    Anyway, I will pick tires by performance stats upon reading some tests, but will definitely keep an eye out for that rubber lip.
    I have no idea how to measure inner clearance, other than maybe when the car is lifted (but I have nowhere to lift it without paying big bucks).
    Thanks for the 235/45 tip. At the very least now I know which width to aim for.
    Aug 10 2011
    330i ZHP
    I was just referring to when using online calculators for the tire size you're looking for compared to what you have. Input what you have for a tire/wheel size, take a tape measure when the car is at ride height and see how many inches/cm's whatever you have to various components such as your fender in the rear. Up front it is helpful to measure to the suspension components when the wheel is turned to full lock. Now that you have a ballpark idea for clearance you will know what you have to play with when the new values are displayed compared to what you currently have when using something like the 1010tire.com calculator.
    Also, your ET is 45, so if you find a tire size you like but it looks like you are going to be hitting the suspension up front when turned to full lock you can consider what spacers might move you away from that suspension while at the same time not hitting the fender. I'm just trying to give you something to work with here, but 235/45/18 will be fine even with sport suspension. Work with 235 as your width in the calculator and just see what you can get away with for the sidewall.
    Oct 02 2015
    πŸ‡ΊπŸ‡¦
    Thanks a lot!
    I've also been told (by a person I trust because he knows A LOT about our cars) that there was a B6 version that came stock with BBS 8.5Jx19 ET 35 wheels - I just don't know which profile (obviously a slim one). And that car had the sport suspension. So at the very least a 10 mm spacer would solve some problems for me (ET 45 -> 35). But I still need to be reasonably sure that the tire height I pick can be fitted, else I'll be losing about $500 USD, you know (going to get a new set of tires, not used ones).
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    The standard tire size for an 18" wheel is 235/40/18 which was what came on the Ultrasport wheels (18x8) which has the Sport suspension. You'll have a tiny bit of stretch going to a 8.5" wide wheel which should give you more suspension clearance.
    USP CLUB MEMBER #34
    Oct 02 2015
    πŸ‡ΊπŸ‡¦
    Aha! So 235/45 should fit no problem, but it's not the best width for 8.5"?
    235 mm + 1/2" = 250 mm. That's one wide expensive tire...
    Feb 23 2004
    Stow, OH
    Keep in mind that with the standard non-Sport suspension, the car will sit higher, but with softer springs and struts, there will be more wheel travel. The key is to make sure you're not going to interfere with the control arms.
    All of these tire sizes maintain the same outer diameter and are the standard sizes that came on the B6 A4 regardless of suspension:
    15" - 205/65/15
    16" - 215/55/16
    17" - 235/45/17
    18" - 235/40/18
    Going to a taller sidewall will increase the overall diameter of the tire and throw off the speedometer. I think you're one of the first to ask to go for a taller sidewall, so there's not a lot of others who can chime in here. If you have a friend who can let you try a set, that would be the best way to know for sure.
    USP CLUB MEMBER #34
    Oct 02 2015
    πŸ‡ΊπŸ‡¦
    Quote Originally Posted by CyberPMG View Post
    I understand that's the only certain way, but sadly, I don't have such a friend.
    I've seen only one person specifically asking for a taller tire (on a different forum), but I've seen at least 4 people saying "screw it, I'm selling these R18 / R17 and going back to stock 16" because the ride is too stiff". I want a new shiny polished set of wheels, and I don't want to be one of those who went back!
    And yeah, I understand speedo / odo implications. Is that not correctable via VCDS, by any chance?
    Feb 23 2004
    Stow, OH
    You can use VCDS to change the tire size to have the odometer adjusted, but you can only choose from a preset list of tire/wheel sizes (the list I've mentioned above).
    USP CLUB MEMBER #34
    Oct 02 2015
    πŸ‡ΊπŸ‡¦
    Thanks a lot for the info. But now I'm at a loss: you said all those aforementioned tire sizes amount to the same outer diameter, but in that case the speedo / odo readings would actually not be affected by swapping tires to a different size form that list. What am I missing?
    P. S. I just ran the math to compare 215/55 R16 to 235/40 R18, and indeed, there's only ~2 mm difference.
    Β© 2001-2025 Audizine, Audizine.com, and Driverzines.com
