Personally I think the only options are the JHM stage 4 and R5 series and the Southbend stage 3 endurance. To me the JHM stage 4 and the Southbend stage 3 are very similar and good for daily driving. The big difference between the 2 is that JHM uses a self adjusting pressure plate that is based on the oem unit with a higher clamping pressure. The Southbend unit is a non self adjusting unit, that should be able to handle more power. I ran the JHM stage 4 unit and the clutch is great, no noise, easy to drive; but the pressure plate couldn't handle the abuse I was giving it. It would probably be fine on a stage 2 B8.5. I really like the lightweight flywheel. It's quite a noticeable difference. I haven't driven a Southbend stage 3, but have heard nothing but good about them even on the APR Stage 3 cars. I'm currently running the JHM R5 series clutch and it is a definite improvement over the stage 4, but it is also more aggressive and takes a different technique to drive smoothly when going slow or in stop and go traffic. Once moving I think the engagement between gears is much better then even the stage 4, which was already an improvement over stock. Break in period for the R5 was not at all fun. It's a sprung 6 puck clutch with a non adjustable pressure plate. I autocross and track my car, and also routinely drive it around town, so I wanted something that I could abuse and still run to the grocery store or out to dinner in. So far it has handle the abuse without any issue at all, and is getting better and better as a daily. I had a hard time deciding between the southbend and the R5, and honostely what won me over was the ability to just change the liner on the flywheel and so the cheaper costs. JHM clutch only costs me around $1,000 for clutch and liner, while the Southbend was $3500. Just by looking at the designs I would think the Southbend would be a better daily, and the JHM R5 would be more robust.
