    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    Quick question in regards to our starter.
    So i noticed my batt voltage has been jumping from 11.3 - 14.0... did a quick walkthrough of the wiring and noticed the nut that connects the + lead to the starter is missing
    anyone happen to know what size the nut was before i go and buy 5 of the wrong sizes? Tried searching ECS database for it but it usually comes with the starter. From some DIY's i know its a 13mm nut, just dont know the thread size.
    EDIT: i think i just found my answer on ETKA, does M8 sound right?
    19' Glacier S4 Black Optics
    Veteran Member Three Rings travrach's Avatar
    Apr 13 2012
    Call or swing into this place, maybe in your area- http://biltriterebuilders.com/
    Dec 05 2007
    If you have an extra 13mm bolt from your car laying around, it is most likely the same. Just throw it on. Or grab the easiest one to remove from your car and bring it with you to the hardware store.
    Jun 30 2008
    Erie, Pennsylvania
    I believe it will be M8x1.25 (metric eight millimeter by one twenty five thread pitch).
    The exact part number is:
    N01111816
    And it is supposed to have a lock washer on it:
    N0120387
    Each are $1 at the dealer, but they would probably not have them in stock.
    Aug 26 2007
    ended up just getting a regular washer and a M8 lock nut. Voltage now holds 14.0-14.2! :)
    M8 Coarse, 13mm
