I have this fault. I clear it but then a week later it returns.
Code:
Address 28: HVAC, Rear Labels: 4G0-919-158.clb Control Module Part Number: 4G0 919 158 C HW: 4G0 919 158 C Component and/or Version: KLIMA FOND H07 0062 Software Coding: 02 Work Shop Code: WSC 02391 785 00200 ASAM Dataset: EV_ClimaContrUnitRearUDS 002015 (AU57) ROD: EV_ClimaContrUnitRearUDS.rod VCID: 2F6DEEC976E81846D7-807A 1 Fault Found: 0034 - Motor for Rear Right Upper Body Vent B10D4 21 [008] - Signal Amplitude Too Low Intermittent - Confirmed - Tested Since Memory Clear
The car is an A6 C7, with the optional extra of quad climate.
9AQ
Deluxe 4-zone automatic air conditioning, includes front control panel with digital display, separate temperature control for the driver and front passenger sides. There are additional controls with digital display in the rear with separately adjustable temperature and blower settings for right and left side (rear functions can also be set from the front controls.) There are additional air vents in the B-pillars and automatic recirculation by means of air quality sensor, use of residual heat, separate regulation of footwell temperature and ventilated glove compartment with a choice of 3 climates: gentle, medium and intensive
