Results 1 to 4 of 4
    Oct 24 2015
    Perth, WA
    ECS Defroster flap motor (green) different to OEM
    Hey guys, I installed this servo but it opens and closes at different angles as seen on the picture below. What is going on here. If i install it, there is no way it can travel completely around due to the length of the actuating rod connected to the flap. You can see in the photo below that the motor arm is 100% clockwise in both photos and the orientation is the same however the final position is very different. They both have the same part number, and even that is a surprise as going off this (where i bought it) it should be a J revision no? https://www.ecstuning.com/b-genuine-...en/8e1820511j/
    Have I purchased the wrong one? Have they changed? How do I go about this?
    Thank you.
    My respray thread
    Oct 24 2015
    Perth, WA
    Ok, so ECS has done it to me again. Audi B7 A4 All is not All. Its LHD only. The light green is RHD and the dark green is LHD. NOT ALL!
    Given that ECS posts internationally, I think it is incumbent that they specify the parts a where there is a RHD/LHD derivatives. Especially when they're the same part number.
    In the end, I prised the green actuator and swapped them from the old one to the new one. The motor itself is keyed exactly the same, so its JUST the little green actuator that is different.
    So anyone from RHD countries, buyer beware!!
    Really annoying.
    My respray thread
    Established Member Two Rings magpies14's Avatar
    Jul 29 2011
    Malaysia
    Did you replaced your defroster for a RHD ? i am looking to replace mine soon... kept getting that defroster fault code....
    A4 2.0TQ '06 * DAKAR BEIGE * Bilstein B12 kit * 034 Motorsport Turbo Inlet Hose * RS4 Rear Sway Bar *
    VFIZ module* S4 Cluster * S4 Door Blades * RNS-E 192C (SW660, HW 54) with Audi Bluetooth Module with SDS, with KUFACTEC Rear Camera kit.
    UNITRONICS Stage 1 with 034 HFC....hmmmm yummy * DTM front bumper with RS4 fog lamp mod (thanks phil) with RS4 replica front grille
    S-line Boot Lid..and Standard OEM Split Five 17" with 13mm spacer front and 15mm spacer rear.
    Oct 24 2015
    Perth, WA
    Yes, I replaced the motor, but had to swap the green actuating arm off the old one onto the new one to allow it to fit.
