I want to do my front bearings. I see that Timken, Moog, SKF have an assembly which includes that housing it seems to live in that has the 4 bolts that bolt to the knuckle. They do not include the hub.
I have found this part number while I was trying to find a F A G for the front. 800941C This F A G bearing states it is for the front but it does not come already pressed into the bolt on housing and no hub of course. So it's simply the bearing and would need to be pressed into the housing and then bolted to the knuckle.
567447B states it is the rear? Of course thats a different setup and I'm just worried about the fronts.
Could some one advise? I have read that F A G bearing balls have an oval shape rather than a spherical shape and I'd like to buy the better product. I'm up in the air between the F A G which seems like more work if I am understanding correctly how that would need to be installed or the Timken/Moog/SKF which are mounted inside the bolt on housing already. In which case which is better moog or timken? I have heard Moog is no longer USA made? Not sure if thats true.
